Thanks all. Just more effort than I had expected.
Is this thread really solving something or is it more chasing after a problem for a proposed backyard garage solution? I'm all for ingenuity, but even at a half banana max DIY guy, it takes me < half an hour to change the engine oil on my 1FZ-FE with factory parts.
Even if it cuts down time/effort by 80%, I still wouldn't take a chance on my 9K mile young 1FZ-FE as there's no R&D to support it whatsoever whereas the long standing approach has been engineered by Toyota and repeated a gajillion times.
Perhaps I'm missing something here which could very well be the case. Gracias.
Never thought of that one and haven't really cared about the mess, But... It's been 8 years since I installed this on my son's 94 to eliminate the startup rattle. Still doing the trick. No startup rattle.I'm pretty sure the main point is to just have the oil filter vertical and reducing the mess during oil change. And getting to list it as a mod...
McGeorge linkI came across a picture of the Toyota 15609-75010
I thought I would add my two cents to this thread. My cruiser went from having the luxury of being able to be parked in my parents garage most nights, to now sitting outside in Aspen Colorado. I have always had a faint cold start rattle that never bugged me too much, but enough for me to stumble onto this thread. I thought I would give this a shot as I didn't see any downsides. Easier oil changes, more readily available oil filters (that have a general consensus as being a really good filter), and hopefully building oil pressure faster which can't be a bad thing. $150 later and I threw this bad boy on before moving up to Aspen.
All I can say is after two months of the old girl sitting outside and having to start every morning in the fridgid temps and I have had ZERO cold start rattle. I can also semi confidently say that I seeing slightly higher oil pressure all over the board, from driving it hard, to idling when its warm, I swear the gauge is 1/5th higher then where it always use to sit.
Knock on wood but my truck has been running very well. 291,000 miles and doing a lot of cold starts with short drives and she's been a trooper still not burning any considerable amount of oil. If anyone is waffling on getting this adapter like I did for quite some time, I would recommend it. Only down side I could ever see with it is there possibly being another spot for it to leak oil from, but that hasn't been an issue yet.
Cheers!
More like $150 now. Are you running the Ford filters, or Mr. T with adapter?I put one on mine. Send like a cool addition. I'm unconvinced it was worth the money.
No issues with it, just not sure it solves $100+ worth of frustrations
