1FZFE fuel mileage
Isn't 87 minimum what the owner's manual recommends?
Higher elevations have lower octane... 85 in Denver is like 87 in St. Louis
There are a few states that run 85, that's why I asked. You also cannot buy non-ethanol in those states.
you can definitely buy ethanol free in Colorado and we use 85 here
True for UT as well EDIT: @OrangeCrusher beat me to it.
@DodgeH8TER, are you factoring the different tire size into your
If you aren't experiencing any pinging, running 87 is just pouring money into the tank for no gain.
Can't hurt anything but your wallet to try a tank or two.
My F150 work truck 100% runs better on 87. It pings badly on regular everytime you accelerate. With 87, I don't notice it happening at all.
Yeah. I did the same thing in my ranger when gas was cheap. Tried 85,87, and 91 but didn't get anything to excite me. But running 91 in the cruiser may help because it will burn hotter and help clean out carbon in the cylinders
Higher octane does not burn hotter. When needed because of Higher compression and/or forced induction Higher octane is more resistant to the destructive properties of pinging and detonation. Which explains why Higher octane sometimes causes poorer fuel economy. In those cases the user suffers a double whammy to the wallet; pay more for the fuel and don't go as far, i.e. MPG is worse.
The 1FZ-FE is a textbook case of not needing high octane due in no small part to its conservative design. Plenty of other examples exist as well.
Of course the "new and improved" current crop of cruisers are many things, but calling the engine design conservative would be stretching the definition a wee bit.
