This definitely might be worth $135.
Just finished installing this newer Ford adapter on my 94 FZJ80 and used this:That filter mount (the threaded one on the bottom) looks to be easily swapped..
Perfect! Just ordered for myself.Just finished installing this newer Ford adapter on my 94 FZJ80 and used this:
Improved Racing Remote Oil Filter Mount Thread Adapter Bung for 3/4 - https://www.improvedracing.com/oil-filter-nipple-adapter-bung-3-4-16-to-m22-1-50.html
It is machined very well and works perfectly, with some Loctite 638 on the adapter side threads to seal, allowing us to use our Toyota oil filters.
Yes that is the new and better one. The collar does need to be swapped if you want to run Yota filters. I plan on using the Ford FL500S due to the pressure relief valve and anti drain back. From what I’ve found it’s a superior design to the Yota and I’m not the type of guy who needs to see the black filter.@logicbyondreaso -
Is this the one you have in your pics?
-Kernals original one/link comes up NLA, but the superseding replacement Summit has looks like what you’re running.
-Did you have to swap the threaded collar that the filter screws to, or is Ford running the same metric pitch that the ‘Yota filter you show mocked in / no need to modify?
Thanks in advance?
I took a quick glance, but didn't see it. If you post this in the classified section it should sell quick.I have a used M-6880-A50 for sale. It needs new O-rings because the originals are pretty hard (you can buy replacements through McMaster Carr), but I will include the old O-rings. HOWEVER this version doesn't need a filter adapter to work like the new version. Has some surface rust on the large bolt that can be cleaned up, but otherwise in working condition.
$80 shipped, but make an offer!
View attachment 2911972View attachment 2911973View attachment 2911975
Will do! I just figured someone following this thread might want/need it. ThanksI took a quick glance, but didn't see it. If you post this in the classified section it should sell quick.
Stupid Q, but how did you remove the existing adapter from the Ford unit to install the Improved Racing one?? I expect it unscrews but I have as of yet been unsuccessful and don’t want to totally destroy it.Just finished installing this newer Ford adapter on my 94 FZJ80 and used this:
It just unscrews, lefty loosey. I believe it's a standard sized socket around 1", I used an impact and it came right off. But used a long ratchet/loctite to put on the new one.Stupid Q, but how did you remove the existing adapter from the Ford unit to install the Improved Racing one?? I expect it unscrews but I have as of yet been unsuccessful and don’t want to totally destroy it.
To remove the adapter you use a large allen wrench that fits inside the fitting. See closeup of photo shared above. Might be an M12Stupid Q, but how did you remove the existing adapter from the Ford unit to install the Improved Racing one?? I expect it unscrews but I have as of yet been unsuccessful and don’t want to totally destroy it.
