More work done on Gunner this weekend.
I cam very close to finishing up the tailgate project. I had a local fab shop bend me an 18ga sheet to form the rear cover as I didn't have access to a brake large enough to accommodate this thing.
I needed to come up with some sort of access panel to get at the latch mechanism so after some thinking, my best 'cruiser buddy donated a FJ60 rear hatch to the cause and I salvaged the small panel off of it.
After some some grinding, hammering and welding I got it installed to my satisfaction.
Then I was able to finally weld the back onto the box frame. I drilled three holes in the bottom to serve as drains, should any water ever get in there, then seam sealed the whole thing with some 3M seam sealer.
I picked up a pair of FST style tailgate brackets off eBay and found a pair of GM tailgate straps that worked out well. Some measuring, drilling, a couple riv-nuts later and, zang-a-rang, I've got a working tailgate!
Got the tailgate project finished up:
Started mocking up the homemade tire carrier:
Hardtop test fitted:
I also found a good deal on a new/unused Con-Ferr 22 gallon auxiliary tank on Craigslist yesterday.
It's missing the mounting straps and hardware but came with a skid plate. I'll probably hit a junk yard and start looking for a pair of straps I can adapt to mount the tank.
This one has a baffle down the centerline but no fuel sender so I cut a 2" hole for a factory sender. The factory sender needed to have the arm bent somewhat to work better with the Con-Ferr tank. It won't quite reach the bottom and I'm perfectly ok with that. When the gauge indicates empty, I'll likely have 3 or 4 gallons in the tank.
I'm debating on whether or not I should have the tank sent out to a shop for rust proofing inside I peered in there with a flashlight and can see a few small surface rust patches and I'm thinking it would be nice to have this sucker sealed up with some sort of epoxy.
Here is a rough sketch of my proposed fuel system setup as well:
