I will not be long on words but long in pictures to document this build.
Goal- Reliable FJ40 to hunt and wheel with. mainly so I would not have to use the 1975 dune beige model in the woods.
Recipe:
1- 1977 frame and body parts with spare 1974 for parts- sourced in Dothan Alabama.
2- Full float rear differential, 350 4 bolt main engine, adaptor, transmission and transfer case, power steering pump and other parts from a guy in St. Louis, MO.
3- 1991 TPI L98 engine that has been sitting on a stand since 1991. Yea, you read it correctly, Street and Legal Performance pulled this engine from a 1991 Pontiac GTA Trans AM to put one of their engines in it. A hot rodder in northern Illinois bought it with the harness, ECU, and fancy serpentine belt system and stored it for 22 years. I got it on EBAY.
4- Man-a-Fre Mojave lift kit, front shackle reversal.
5- 4x4 Labs Hysteer system for a spring under system.
6- U-bolt flip kit
7- Aqualu aluminum tub with rear storage tailgate and drop rear storage box in bed. sourced from David S. in Gainesville, GA
8- Lift rear hatch from a 74 with gas struts in the tubes instead of springs.
9- BFG- 33x12.5x15 mud terrains.
10- Lunch box locker in front differential
11- 3.70 (EDITED 2/19) gears in differentials
12- Saginaw power steering with 4x4 Labs mounting kit.
13- Old Air Products Hurricane Heat and AC system.
14- Corbeau Moab Seats
15- Bib from a 60's FJ40 with amber lights. Thanks to TEXICAN
16- All Glass is tinted.
I started with parts as you can see in this first set of pictures.
Recipe:
6- U-bolt flip kit
