How To: Replace your own steering rack
Hi all,
I finished the rack and hose replacement in my 06LX yesterday. Had a tough time with removing the intermediate shaft off the rack after removing them as a pair. Took a lot of heating/cooling and penetrating oil and hammering and frustration. Also I was able to remove the return line with a crowfoot flarenut, but the line itself got bent badly. Luckily I had bought the Sunsong return and high pressure line set from Rockauto. Just have to get it aligned now. I was a little off on the alignment/adjustment but don’t have the heart to adjust it. Remember to hook up the oil line harness too!
Thank you for all those who posted the instructions and pictures!
What a beast of a job. Took a majority of the day.
Can someone tell me if the shaft allows for some movement? I notice I also tore the dust seal at the firewall perhaps from the beatdown/frustration from removing the shaft from the rack.
I didn’t have a problem with removing the lines.
Sunex 971017 3/8" Drive 17 mm Fully Polished Flare Nut Crowfoot Wrench Amazon product ASIN B00JRYTHSG
Do you mean can the steering shaft go longer/shorter? I believe it can.
Collapsible steering shafts (intermediate shaft) have been around for decades. They are designed to collapse in the event of a collision to protect the driver from being impaled by the steering shaft.
Just did my second rack this weekend (heads up: don't go cheap, you know better). The first time took me an entire weekend, and this second time took like 5 hours moving slowly. Jacking the engine up is the way to go, appreciate the advice in this thread. Fiddling with the oil cooler was way worse.
I just wrote up this long how to for member who PMed me so i figured I may as well share it with the masses.
98 LC 200k seemingly well cared for miles, but this is def its first rack. Its now strictly for off road use.
This is not a 1 banana job. But anyone can do it with a day, maybe a friend, and some 4 letter words.
My dad was there as well as a friend that owed me from a couple weekends of working on his Disco, if he wasnt a good friend and didn't owe me some time he surely would have left half way through.
Tools:
metric wrenches
2ft of extensions
univesal joint(s)
good socket set
creativity
a friend
beer
Supplies:
-New Rack-Got mine from Toyota through a friend for $530 brand spankin new. Retail was $700+
-I also went ahead and did the poly bushings
-1 gallon of coolant
-1/2 quart of oil
-2 quarts of power steering fluid
I also did my ball joints while i was in there, and after all the challenges and cursing i got a little over taking pictures. I will post what i have but as other people do this job, please take pictures.
I did the ball joints WITHOUT a press, it is possible to do without messing anything up as long as you have a good sized hammer, sacrificial nut and a good pry bar set.
Alright, from memory here is the order of operations that worked for me strictly for the rack.
1 car in the air, tires off skidplates off(duh)
2 stare at it a long time and get the lay of the land in there.
3 remove the oil filter and housing. Be ready to catch about a half quart of oil, and half gallon of coolant. It will get everywhere, and it sucks.- there is a 14mm bolt 2 12mm bolts and 1 12mm nut that hold this adapter bracket to the block. These are accessed through the frame hole that the steering rack threads through on the drivers side. I used extensions, shallow sockets and a universal joint to get these off. Be creative, these are not fun bolts but by going from outside the frame rail they seemed easier. Carefully remove from the area and be sure to preserve the rubber gasket in there. If it removes easily and is still pliable reuse it. [UPDATE: after a long road trip and 2 days of wheeling this gasket is seeping oil, i tightened the bolts and it had no effect so put some thought in getting a new gasket!]I did and it sealed great(at first). There is a coolant inlet and outlet on the housing there are simple compression clams that just get slid down, and the rubber line gets pulled off, check to make sure these aren’t cracked.
4 remove the 10mm bolt that connects the rack to the steering column. May need to put the key in the ignition and rotate the wheel for easy access from below.
5 using a 17mm(I think) socket and 3/8 drive ratchet remove the forward hard line from the rack. Be ready for some fluid.
6 using a 10mm and ¼ drive ratchet remove the little bracket that holds stationary the 2 lines as they run across the front of the rack. You will know what I’m talking about when you get there.
7 guide the line that you had just removed down so the remaining fluid can drain. At this point you should have some nice open space to get to the rear line. Don’t attempt to remove it yet.
8 remove the 2 bolts that thread vertical on the rack. There are nuts and they will need to be held to remove these bolts. Easy money
9 there is a u bracket that holds the other side of the rack. The front one should be relatively easy. Use the tools you have to back this long bolt out. The back one is…not strait forward. I had the best luck with about 2 foot of extensions and a universal joint to get it off. Im including a link to the few pictures I did take and you will see what I’m talking about. Once broken loose, it becomes an easy job of bolt removal
look close and you can see where the socket is connected, and the top left of the photo you can see an extension. Also isllistrated here is the frame hole that i accessed the oil filter housing bolts from on the other side.
9a -remove the rear line with an open end wrench, this will take time, once it is broken loose it will be 1/4 turns
10 WITHOUT removing the tie rods from the upright, break the nut loose on the rack and twist the rack ends until it is no longer connected to the tie rod. Do this on both sides. With the rack still connected but loose from the steering wheel, turn the wheel all the way until it stops RIGHT. This will make the short end of the rack be on the drivers side.
11 Fenagle and disconnect the column from the rack, FORCE it passenger side with extreme prejudice until the end of the rack is out of its frame hole and the hard stuff is done.
12 go back in with the new rack again with it pushed all the way passenger to fit. Be sure to attach the old had line bracket to the new rack.
13 With the steering wheel strait, measure the rack from boot end to tip of the threaded end, make sure both ends are the same length and connect the steering column making sure the steering wheel is strait.
14 connect the rear line with the rack still loose. This will be a 17mm wrench doing 1/8 turns. With the rack loose, it makes things easier.
15 connect the front line
16 install the oil filter housing being sure not to pinch the gasket
17 bolt the rack down using the 4 bolts
18 connect the rack to the tie rods and make sure the flanged end of the nut is installed correctly that is used to tighten up the tie rods. Using your eyeball, make sure the toe is as close to 0 toe as possible and tighten nut down on tie rod
19 add steering fluid, add coolant at radiator, add ½ q of oil, start truck, add more steering fluid and coolant. Move the steering back and forth a few times. The pump will sound very unhappy but this will go away after a short drive when it works all the bubbles out.
20 skid plate
21 take it for an alignment AND ASK FOR 0 CAMBER, for some reason the book at the place I was taking it to required positive camber…nuts.
sorry for the lack of pictures, but this should get people going the right direction.
thanks for this brother, couldn't have done it without this write up
Hey guys, reading through a lot of this thread tells me there's a bunch of ancillary parts and bolts to replace when doing this job. Is there a post I missed that lists all the P/N's? I will be forever in debt to whoever put one together.
Edit:
OMG @Ayune that PDF is fantastic. I'm so sick of looking up P/N's for my truck between diffs, axles, drive shafts, gaskets, exterior push clips, etc etc.... I owe you like 5 beers.
Second question: I have a Detroit Axle reman in my garage, bought it about 2 yrs ago when this whole ordeal started (longer story, relates to re-gearing, lockers, etc)... but its going in sometime within the next week or two.
At the time it seemed like MOST people (random issues occur) have had a lot of luck with Detroit Axle reman's. Is that still the case? ZERO CHANCE I want to do this again anytime soon.
Throw it in the dumpster. Mine leaked on installation. The inner tie rods are junk. My DA reman leaks half a quart every 800 miles.
Did this job over the weekend and thought add a few thoughts. First, thanks for all that went before, it was definitely a time-saver having their 'experience' going into it.
First, I installed the Toyota rack in my 05 LX. No issues with the Toyota vs Lexus rack and saved a few hundred $$.
I bought the Sunsong pressure and return line to have in case I had issues getting the return line off the gear. I'm glad I did because I don't think I would have gotten it off in a usable condition. I didn't waste a lot of time fighting it and just cut it off with a dremel (thanks to advice of others here). To get the linkage off, I loosened the top two bolts closer the the firewall, removed the bolt on the linkage at the gear and was able to use a drift punch to drive the coupler off the gear without too much trouble. I replaced the radiator at the same time and was thankful of the extra space that opened up to work. The Sunsong lines fit OK, but not great. Mine needed a little massaging to get them to clear other lines and the gear. The bends were close to the OEM, but not perfect. I haven't decided if I'll go ahead and replace with OEM or not-- the OEM price for the pair of hoses is a little ridiculous. So, the Sunsong is certainly a viable option in my opinion, being 1/4 the price of OEM. The other thing on the Sunsong lines, on mine at least, is they only came with two crush washers. But you need four for the two banjo fittings. I bought a new OEM PS pump too, and it didn't include the washers either., fyi. So, I'd order 2-4 crush washers or have access to them somewhere before starting.
After all the fighting to pull it out I was nervous about getting the new one back in without snagging the rubber bellows, so I taped the heavy cardboard tubes they used to ship the rack onto the rack as I installed it and that seemed to work well to protect the bellows.
No excitement in the job thankfully. Not fun certainly, but doable.
I’m putting a new rack in a 2001 Landcruiser with 300,000 on original rack this weekend.
I have been collecting parts and making sure I’ve got everything for the job.
After reading through this thread, I have a couple questions.
What is supposed to connect the high pressure line to the rack itself? The gates hose I purchased looks like it needs a bolt and some other fitting to connect. Pic attached.
Has anybody replaced the 2ish foot hose going from the reservoir to the pump?
High pressure hose ^
I am assuming this bolt/fitting will be reused from the old rack? Just wanting to ensure I have everything for the job.
Thanks
Should work, however the OE one at the rack looks like this.... I'm guessing so you don't lose one when installing?
44327-30030
90430-16168 (2)
I forgot to replace this when I did the rack... Luckily the truck is still on jack stands and I didn't put fluid in it yet. Lol.
BTW, this job sucks as much as people say. For the random people who said they did it in 6 hours or so, I don't believe you. :D
Check partsouq. Much cheaper.
The top return line (44348-60240) is actually cheaper on Wits' End as opposed to Partsouq by $27.12 after shipping. The bottom feed line is not sold as an individual part and is only available as part of the entire formed hose assembly ($450-600).
