I have to remove a damaged Asain hub from my rig but am having a hell of a time getting it off
. I am ready to break out the BFH. Anyone have any tricks to remove these suckers? Thanks
Howdy! The cone washers have a split in them. Try to catch that edge with the punch and knock them sideways. JohnThe PO crashed and bitched up the bumper,fender and dented the housing of the hub preventing it to turn on or off. I smacked the hell out of the studs with a brass punch trying to loosen the cone washers but i'm still stuck. Heat maybe? Thanks
If the cone washers have been on there for awhile, they can be stubborn to break loose. Gotta be patient. I use a brass drift on the end of the stud, just keep striking it with a hammer. Might take 40 or more hits before the cone pops loose. Heat and penetrating oil help. Patience and good aim with the hammer are key.
I use the screwdriver as mentioned above and if that doesn't work, I hit the side of the housing, not the stud. the problem with the hub studs is that if you start hitting them with the punch, they bend...or maybe I was wailing on them too hard.
bk
bk
