- Joined
- Jun 21, 2011
- Threads
- 233
- Messages
- 21,829
- Location
- Redding, California
- Website
- trail-tailor.com
SORRY I HAVE TO PAL!!!
J
J
I knew it was sweating for the last week, and added some stop leak, and it got better.Good luck, was there any indication the radiator was going bad?, added leaking coolant lately or was it overheated before breaking?
Dont want thisin forest.
Got a few hours down this weekend, swapped the water pump and belts while access was easy.
Finished the bracketry and wiring for the passenger seat, and got both mounted. Had to get creative with passenger side, to work around the rear heater.
I got some help from a set of smaller hands for the tight stuff!
While I had the seats out, I chopped the tab on the locker handle.
Earlier I could not engage them separately, pulling front also pulled rear.
Quick-fix quarter panels are in progress, just sheets of ply to seal things up and have somewhere to mount the 6x9 kickers.
Was going to service rear drivers drum brake, but I got the wrong wheel cylinder....
Swapped a cv, was out of time to do the other side.
I think you are correct about that, on the dash mounted 7 series and such, that you have to engage rear first, then front.It was my understanding that the front locker couldn't be engaged unless the rear was engaged first?? So, in theory, you made a bypass to be able to lock the front independently of the rear instead of in conjunction with??
J
You got me there...!!COME ON NOW!!! We know those are your pretty nails... Almost as SEXY as those cable lockers... BUT! NOT QUITE!!
J
I keep my nails clean, and they fit in small places
No, really, she's helping out allot, she swapped in the rear manual window regulators from the donor, lubed them up and all!
(Rear passenger doors are manual)
Sorry for the late reply, but now I can answer a bit more.was thinking about going this route.. Then I could just rip it off if I don't like the look. How do you think it would hold up on door handles?
Yeah, here is some of the mud partsdamn dude .. looks like you having some fun !
