Spudman--where did you get the caster wedges from? My steering wonders a lot (new TREs) and I know it's because of the OME lift installed. Thanks
Spudman
SpudmanGreat stuff. I'm only a few pages in. If the MIG is splattering then you might have the gas set to high. You could try turning the gas regulator down to the min. Put your ear to the nozzle and press the trigger, you should not hear any gas getting through. Then turn the regulator up slightly and press the trigger again. You should hear a faint gas sound. Less is more when it comes to MIG, especially with thin plate. Maybe even think about a TIG welder those things are the bomb!
when you want to weld with gas less you have to change the positive and negative around, something I found out after I bought the new one.
What make is the LED light for above the windscreen and where did you get it?
Didnt realise it was a fluxcore gasless MIG. Thought that would be a but hot for panel work! Guess not.
SpudmanThanks mate, I've actually since bought a new one, but I did end up finding what the problem is.when you want to weld with gas less you have to change the positive and negative around, something I found out after I bought the new one.
Enjoy the read, I thoroughly enjoyed doing the work![]()
Spudman
