Hi everyone
Today I fitted a pair of gas bonnet struts to my 60,
I've done a search and haven't been able to find any threads so I thought I'd post up an easy How To
Firstly I purchased these on eBay for $20
http://www.ebay.com.au/itm/111244174558?
Now they're are no exact holes for these struts to line up into, due to the 60 series have never had bonnet struts fitted.
The first thing I did was remove these brackets
Where this bracket bolts to the bonnet, you need to remove that small bracket by grinding the rivet off so you end up with a bracket like this fitted to your bonnet
Then you can mount one of the bonnet strut bolts onto that bracket
Now if you look on each inside fender (wing) there is a hole available where you can bolt the other strut bolt (the little one)
So you do that on both sides and then fit your gas strut
And that's it, the bonnet closes perfectly, it actually sits a little bit higher than with the old bonnet stay, so pull the bonnet stay out and give it the old heavo.
The size of the gas struts are 410mm for anyone looking to buy a set other than Australia
I'm very happy with the result
