Welded 2” at a time, started at the center hoping that would warp the ends of the long truss before it would warp the housing. I let it cool to room temp before i welded again, took 4 hours to do the welding. I also kept turning the hub by hand to feel if it got harder to turn, never felt any difference but thats no a great measurement, but if it seized up that would be a sure sign of housing warpage. Thats about the best i could do in my shop with the time frame i had to do it. @Broski i wish i had a rod of the correct od and a spare diff housing to setup like you did with yours(nice work btw) but i didnt have those things so i did what i could.
I havent chopped the stock frame side mount yet, i will once i feel im happy with what ive done. I still plan to raise the tierod to the higher position between the stock steering arms and the slee arms, the stock frame side mount hitting the tierod during susp compression. I also plan to gusset both ph mounts once i know theyre are completely permanent. I havent flex tested the truck on my alignment lift yet with this new setup, maybe thatll show me a few new things.
Assuming all the above turns out good, next will be hydro assist. Hopefully i can get to this soon.
