Beowulf said:Did you mean to say the dizzy cap?
Any chance some of the grommet dropped into the valve cover?
Please clarify: Did you lose the screw inside the valve cover or not?
i second that emotion. see the mini-fiasco that honda has on its hands with the cr-v.cruiserman said:I would verify the old oil filter seal is not still on the block.
Rookie2 said:Do good oil filters have some kind of bypass mechanism in them so that if the filter gets clogged up, it bypasses the filtering process? Or am I dreaming something here?
aamiggia said:What would happen if the old oil filter seal was still on the engine? I'm assuming that the oil filter would not seal properly and you would get oil seeping from there, correct?
I can tell you for sure that the oil is not coming form the oil filter, anywhere from the block, or the head gasket. It looks to be coming from the head or higher and running down not spraying up.
So the worst case cenerio is that I have a cracked head. From what I'm hearing from you guys, there are no high pressure oil channels close to the observed location. So if the head is cracked, I would not get such a high pressure stream of oil. Also, I would assume with a cracked head the problem would be consistent. So far it's happened once before and went away (intermitent).
Can someone tell me if the oil pressure is normally very high under the valve cover? and is the oil filter the main path for the return oil?
