Harrop ELocker | Toyota 4x4 Differential Lockers | U.S. Dealer
cruiserbrothers.com
I’m going down the road of installing a rear Harrop in my 460. I ordered from Georg@CruiserBrothers last weekend. It should get here next week.
orangefj45
forum.ih8mud.com
A11114 Harrop Elocker
Rear locker for Toyota 4Runner, FJ Cruiser, Lexus GX 460
www.cruiserbrothers.com
I do have some good leads already from GXOR-WA but the challenge is finding an installer as most either won’t install a Harrop on a 120/150 series or only do ARB. This is in Western Washington.
I am going to use a 100 series rear diff switch and I do not plan to regear at this time.
This is 80 series switch but going to pick up the wire splices and male connector for my 100 series switch.
Male Connector: Toyota 90980-10631 $4
Wire Splices (x3): Toyota 82998-12170 (165mm long)
Anyone else here in forum running a Harrop on a 460 or a 5th Gen 4R for that matter?
Other than changing my diff fluid and knowing the basic functions of a rear diff..not my expertise to install this myself.
I plan to do all the basic wiring and switch as that looks fairly simple and feel comfortable with that.
••A question I have and hope someone can answer is what other hardware will the installer need assuming they have the basic tools for this job?
Would it be wise to pick up a kit like this?
Toyota 8.2" Master Install Kit
This is a full set up kit to do the job right. It includes: Carrier bearings Pinion Bearings Pinion Nut Pinion Seal Crush Sleeve or Preload Shims Pinion Shims Loctite Marking Compound Adju
eastcoastgearsupply.com
Looks like the differential gasket or is this an area where they would seal back up with RTV? Saw some debate on a 200 thread about cork, gasket, versus RTV.
I see this FIPG mentioned here - 00295-01281
Or is less needed if you don’t plan to regear?
A good time to replace the wheel bearings as well or a requirement with this kind of work?
Wheel bearings seem to be in perfect shape but usually replaced when the axles are removed?
What part of this install am I missing on the hardware installation side?
Admittedly not knowledgeable much at all in this area and appreciate any feedback good or bad.
Installation Instructions
https://lexusgxor.com/_media/general:harrop_installation.pdf
A couple other threads here:
Harrop Eaton ELockerTM / Yotalockers.com: Info / Installation - https://forum.ih8mud.com/threads/harrop-eaton-elockertm-yotalockers-com-info-installation.849313/
Oh yes I did! Harrop/Eaton E-Locker thread - https://forum.ih8mud.com/threads/oh-yes-i-did-harrop-eaton-e-locker-thread.899689/
•• FYI: I've added a few placeholder posts to reserve space at front of thread.
Regards
Acrad
GXOR Member Experience with rear Harrop on 460
Facts about Harrop Eaton ELocker Engagement
We talk through and demonstrate the design and functionality of ELocker - selectable diff locker engagement technology.https://www.harrop.com.au/shop/4x4-per...
www.youtube.com
TECH TUESDAY || Don’t Buy A Locker Until You Watch This!!
Use Code: BNB10 For free diff breather kit and free shipping!https://www.harrop.com.au/shop/4x4-performance/driveline/elockerTIMESTAMPS:Standard 4WD System 1...
www.youtube.com
