can you post a photo of exactly what your looking for?As the subject says, l'm wondering if anyone has a model for a filler piece that works with OEM Prado 150 tail lights. Thanks.
I think that the bumpers and tail lamp housings share a taller waterline on the Prado 150 than the GX460. This lends to the suggestion that one choosing Prado 150 tails should also buy the bumper and lower lamp assemblies.As the subject says, l'm wondering if anyone has a model for a filler piece that works with OEM Prado 150 tail lights. Thanks.
If you need help you can use the FSM, found here: GX 460 Manuals (it's also on the main forum page)
Then you'll have the part number and get some good pictures.
As a suggestion, you could look for STL models of the 150 on line, I know there are some out there, some for free, some to pay for.
These have usually all been scanned from full sized vehicles.
If you get one of these, with some software, Blender, Meshmixer or?? you can delete everything but the taillight.
Although you may need a large build volume for your print. My largest volume printer is a Creaality K1 Max with a 300mm x 300mm x 300mm build volume which is nice.
Anyways, hope this helps.![]()
That might be the one I was thinking of.Read through this thread: Builds - Good luck Kiichiro! A build story. - https://forum.ih8mud.com/threads/good-luck-kiichiro-a-build-story.1115968/
GreenbowCounty was a contributor on this forum. He purchased a 2011 GX and did a full Prado conversion. He may have mentioned the part you need.
Sadly, he sold it and has since moved on.
