Builds Hammersaurus Lex - The LX470 gets tons (5 Viewers)
This has been really impressive to watch and your non-nonchalance about the scale of the project is enviable. Just curious, what sort of background taught you the skills and knowledge to take this on solo? I've seen your 80 but presumably this is a very different scope to build than one already running a SFA.
Thanks. I am not really sure, to be honest. I just like doing it. I don't think it's really all that hard at the end of the day, it just takes commitment and a willingness to light small piles of money on fire.
Battery moved a little, new mount made. coilovers reservoirs mounted, cables and brake lines run, m/c bled, bare metal painted and sheet metal edges covered. ps system bleeding still... Etc etc etc
But she is on the unicorns. With no coilover preload it's looking like about 1.5" too low which is perfect. Tons more to do but technically I can drive down the road all slammed like that.
Awesome! I'm really looking forward to "The Hammers" photos to show us how fitting the name of your rig is.
I will try not to dissappoint
The hard part is the rear fenders. There is not easy way to cut/trim. Might be easier to move the rear axle back, like popular with arctic trucks.
Can't be much different than the 80
Oh, I thought you were trimming big in the rear, like the front. I figured 42's and a 5" wider axle would require a bit more room.
Well I will desire the same sort of travel. Front is harder because wheels turn
Started working on the rear. Got the rear axle removed. Listed for sale if anyone wants otherwise it'll get slowly sent away in the recycle bins
Rear axle is on jackstands. Debating where to put links. May go with a 3 link in the rear to avoid having to make new upper link mounts that properly triangulate. Minimizing sheet metal removal will sort of dictate the axle placement:
Curious what your total width is? Those 100 rear axles are really strong and light. Hopefully someone can use it.
Good question. Seems wasteful to toss an axle but I don't have a ton of storage space
Save an old rear control arm or two, the bushings make really great engine mounts
Nice. That's a pro tip right there. I definitely will.
Not sure what the stock 100 series motor mounts look like but if they're the glued rubber/plate style the driver's side can pull apart once you have dual cases, lower t-case gear, etc.. My 80 link bushing mounts transmission zero vibration to the cab but also allow almost no engine movement. They're perfect
My 80 mounts seem loose. Are they the lame type?
What is your plan for gearing besides the 5.38 axle reduction? T-case to ~3.1:1? Trying to turn 42s with factory t-case gearing and 5.38s doesn't sound like it will work. Could you get adaptors made to fit the 100 series t-case and trans for a Marlin Taco Box built for the 2UZ in a Sequoia, Tundra, GX, 4R? Is there an Atlas that would work? I potentially want to do a 3-link front with coilovers on my 100 eventually and there does not seem to be gearing to keep up with the suspension. Nice build and I also don't see the point in putting time and money into radius arm SAS.
I will put the low range gears in the t case.
5 speed auto has a nice lowish 1st gear. Other than that, nothin. On my 80 I ran 6.17s in the axles and it works well enough for me even with the a343f.
