I hope to have CDan's order by early next week and will get started.
Your parts went out.
Some things to mention/comment on:
After everything is apart and you have completely disassembled each end and you have the gear oil out of the diff., I like to take some quick drying brake parts cleaner and spray the inside of the diff down and let it all drain the gunk inside the diff. Then I use some compressed air to clean out the brake parts cleaner. You'd be surprised at what other gunk comes out of the diff. You are going to be putting new gear oil in anyway, so it's no big deal.
While I think taking apart the birf is important, it is not necessary. I let the birfs soak in diesel or parts cleaner over night, clean it out with brake parts cleaner the next day, and start stuffing the birf. If you are not clicking, swapping sides won't be really any more useful.
I prefer the Martack as opposed to the c-clip for keeping the axle inside of the birf and both of mine are done with this method. Do a search under "Martack" and you'll see what I am talking about. It's a one shot deal and works great...at least it has for me and tons of mini-truck/4 Runner guys out there.
I prefer to use a slightly higher pre-load than what the FSM calls for. And I am only talking a few more pounds, not ten or twenty. The FSM, IIRC, calls for 7-12 pounds range for the pre-load on the hub assy. I like to go to about 15-18 pounds because of the fact that the hub loosens immediately once you put everything together (which is why they call for tightening and loosening). Commercial airplanes also use a 2 bearing hub on spindle assy (at least most of the ones that I've seen airplane mechanics work on) and most of the airplane mechanics I have talked to say they tighten pre-load just a bit over spec. A very well known 80 series mechanic has also confirmed that this is a method he uses as well.
A few other pointers:
-use old races to pound new ones in (trunion bearings as well as wheel bearings)
-don't over fill the knuckle cavity
-don't be afraid of pounding the crap out of old races to get them out using a steel chisel, not a brass one.
-be light on the felt/rubber/metal seal on the outside of the knuckle housing. These break easily--ask me how I know...
-take frequent #6 breaks. It allows you to enjoy the messiness of this job.
-use some lock tite (not necessary) on the lower knuckle studs, and a bit over torque rating won't be a bad thing.
-if this is your first time, use a torque wrench.
-parts cleaner and brake parts cleaner cans are essential.
-reuse bearings if they are not bad and save money. Trunions I would replace regardless, wheel bearings can go a long time (my preference are the Koyos, but the Timkins do a good job too)
Have fun and learn about your truck.
-o-
Riley
