Fzj80 A/T shift linkage removal
washington dc
Hello folks,
I snapped off the nut that secures the trans shift linkage đŸ’€ is this something that can be replaced with out opening up the trans, or any idea how to fix this?
That’s not so bad. Was expecting it being the shift rod that you snapped.
Just remove with an easy out.
The FSM shows the center of the rod protruding past the nut that secures the NNS. I would think that if the nut "broke" you should just source a used one from someone. Perhaps you can post a picture of what broke off.
Could you post up a couple more photos including one looking at the shaft
from the side?
How often does this rod become damaged when replacing the NSS (IDK)??
So a generous application of penetrating oil to that nut/threads prior to removal might help??
Any idea where to get this shaft from? or part numbers, I cant find anything
It looks like they are listed in the post just above yours. You probably were typing your question as the answer was being given :)
Do an internet search for Toyota Parts Online or go to your local Toyota dealership parts dept.
You need to replace the shift rod with a new one. It’s a pain cuz the valve body needs to be removed. It’ll look exactly like this:
I'm replacing mine right now but I can't figure out how to get the set rod out of the oem one in the trans. I know it's threaded but its not allen head and hollow. and can't get anything on it. How did you get yours out? Did you drill it? I'd like to avoid drilling being inside the trans and all. Help would be much appreciated!
Were those dings present when you first removed it?
Can you post up another photo taken from a bit further back to show the entire assembly?
