So with all that being said (get to the point already!)
A simple 3 gang fuse block can do away with the yicky fusible link forever. The fuse rating needs to be just a bit higher than the sum of all the loads that are carried on that particular fusible link wire. A 40 amp regular old fuse seems to be fine. And if it blows for some reason, a replacement is only as far away as your hardware store, and costs very little.
@Output Shaft , did you go this route with yours, then? Can you snap a picture to share, or perhaps share some part numbers/sources for your fuse block?
