Front Drive Shaft (AKA CV’s) reboot, Help! (5 Viewers)
I only have 2.2 & 2.4mm hub flange snap rings on hand so it will be day or so more until I test drive.
Standard 2.2 (2.16MM) plus .46mm feel gauge.
Good update- I told ya those replacement band clamps are hard to get to crimped to factory spec with the pliers type tool- requires the OTC Tool I suggested.
I really need to get that tool before any more band tightening.
Be cool if you post that/those tools in this thread also;)
This is the tool
OTC 4722 Stinger Heavy-Duty CV Boot Clamp Installer
Link: tool
I came across this interesting bugger for pulling CV axles, no experience with it but it looks like an interesting way to pull the axle out with out hammering it
Puller
THX @abuck99 I'm going to get that for my tool box, sooner or later I'll need it.
With snow predicted for tomorrow I wanted to get this front end button up. So I managed to get the last 2.6 mm SR (snap ring) in the state today, 30 mile drive and twice the price but happy to have it.
Wheel bearing breakaway pre-load set to 12.5lb on both PS & DS.
PS hub flange to SR gap was >0.04mm with the 2.6mm SR. DS was 0.15mm gap with a 2.4mm SR.
So next I torque on the calipers to 90ft-lbf, attached the speed sensor and brake line brackets and mounted the wheel & tires.
Then put ~1.8qt of M1 75-90 LSD in the differential and button up with new drain & fill plug washer (gaskets).
I was on a roll, and felt it a good idea for test drive to lube propellers first. On a roll until I pulled out my pneumatic (Harbor Freight) grease gun. It's great once I get grease gun flowing, but getting it primed, is a 30 minutes job on a good day... PITA. But it really works well for grease the propeller shaft slip yokes and spiders. A little trick I learned; is to massage slip yoke seal with grease, then used the pneumatic power and compression of drive train to pump yoke in and out. Gently, not exerting to much pressure on differential & transfer case with the pneumatic pressure.
Worked like a charm again, as grease passed the seal(s).:rimshot:
Finally the test drive. It was sweet no vibration, handle was tight and steering true. This was also my first drive since pulling intake, and it ran like a dream. The Redbarons' got pep.:steer::steer::steer:
Vise made easy work of filling outboard boot with grease.
1425928
Took all my weight on crimpers to tighten outboard clamps, and they could still take more squeezing if needed. Those are for sure heavier than the factory clamps.
1425929
1425931
They changed snap ring so it no longer has eyelets. Unfortunately my various snap ring tool attachments disappeared long ago. Made getting on a little more difficult for me. One went right on the other kept slipping off my tool (5 min extra).
1425930
1425932
I know the grease for the inboard and outboard joints has different part number. Do you know if they are the same grease, just different amount?
Same grease.
