THX
@abuck99 I'm going to get that for my tool box, sooner or later I'll need it.
With snow predicted for tomorrow I wanted to get this front end button up. So I managed to get the last 2.6 mm SR (snap ring) in the state today, 30 mile drive and twice the price but happy to have it.
Wheel bearing breakaway pre-load set to 12.5lb on both PS & DS.
PS hub flange to SR gap was >0.04mm with the 2.6mm SR. DS was 0.15mm gap with a 2.4mm SR.
So next I torque on the calipers to 90ft-lbf, attached the speed sensor and brake line brackets and mounted the wheel & tires.
Then put ~1.8qt of M1 75-90 LSD in the differential and button up with new drain & fill plug washer (gaskets).
I was on a roll, and felt it a good idea for test drive to lube propellers first. On a roll until I pulled out my pneumatic (Harbor Freight) grease gun. It's great once I get grease gun flowing, but getting it primed, is a 30 minutes job on a good day... PITA. But it really works well for grease the propeller shaft slip yokes and spiders. A little trick I learned; is to massage slip yoke seal with grease, then used the pneumatic power and compression of drive train to pump yoke in and out. Gently, not exerting to much pressure on differential & transfer case with the pneumatic pressure.
Worked like a charm again, as grease passed the seal(s).
Finally the test drive. It was sweet no vibration, handle was tight and steering true. This was also my first drive since pulling intake, and it ran like a dream. The Redbarons' got pep.
