- Thread starter
- #81
Remember you will be winching a fully loaded vehicle in less than optimal condition.Temperature and humidity is super high so a 12000 pound winch should be the minimum.Most guys I know in Central America are running the Warn 16.5 thermo winch on there bigger rigs because all the rest fails after a while.If you really want to get to the remote mountain villages you better be prepared.If you stay in populated areas with other vehicles around you can put a 9.5 on it and use a snatchblok and if it fails start walking until you find someone to set you free![]()
Ok, well that's a bummer cost wise but I def don't want to burn one out right as I need it!
BTW I had an aftermarket A/C installed in my 40 in Panama and it costed me less then a 1000$ everything brand new using parts they have overthere so no problems if something fails.
Joe
Well ok cool (literally) maybe I'll wait for that then, but I'm sure the wife might not want to wait.
Thank you sir!
-Daniel Kent
EDIT: If there's anything I should get from there I might get it on this Dec. trip and bring it back on the plane and install it here....i.e. tires, rims, AC, etc. Suggestions are welcome!
