FJ60 gets an EROD and NV4500 (1 Viewer)
Stripping the engine bay for paint, frame is getting painted as well.
Welding up our trans and engine mounts too.
Above pics of exhaust is 2.5” into the muffler and 3.5” out the back.
Cheers
Me and gm mechanical fans do not get along well.
Most folks go electric, even GM depending on gen.
Here is my thing; had a v8 60 and a v8 80. Have had v8 chevy work trucks. All these have been mechanical fan. Have also done a v8 swap in an 80 with electric fans. Mechanical fan will pull way more cfms, no power draw. In all my years with Chevy v8's, none have ever had over heating issues except the v8 60 which had a crap fan shroud. So custom fan shroud and the right fan and problems gone. The LS swapped 80 with electric fans, no probs keeping it cool but did run a bit warm in summer months, 195-205*. Intake temps on 100* days got extreme causing issues, IE 200* or more. Logging hundreds of thousands of miles on GM v8's in stock configs never have had cooling issues.
Any ways, myself, I like mechanical fan set ups in v8 or diesel swaps. Just takes the right shroud in my opinion. I would rather have a hp draw vs a power draw and mechanical with a proper fan clutch doesn't care about things that make electricals upset.
What has made this swap challenging is the LS3 intake manifold vs vortec with the mechanical fan set up. It was never offered from GM in this config, vortec is much taller offering more clearance fan to shroud to intake. Certainly would be better with as vortec intake manifold for clearance but regardless, we made it fit. That and mating the LS3 to the NV4500, another never offered from GM. Sum it up; doing it this way with the crate ERod, mechanical fan, NV4500 has certainly complicated the swap. However, it gets you an Erod in a more "truck like" config, I am looking forward to the test drives!
Cheers
Are you aiming to pass emissions with this?
Cheers
My main issue was the fan clutch. All the fan clutches I tried locked up at wrong times/temps. For example I would be cruising the highway at 75mph and the clutch was fully locked. It was unreal too how much power it sucked away locked up incorrectly. I tried a few oem gm clutches and 1 aftermarket clutch. They aren't serviceable either like Toyota. I think i got one that worked so so, but still locked up wrong. Also i got temp creep at idle in drive when it was really hot out. After a couple hundred bucks in fan clutches I threw in the towel and went electric which is not perfect either. There are pluses and minuses. I almost went with a toyota clutch but i decided it was enough. Was really, really weird. I'm not saying your doing anything wrong. Just discussing tech. Maybe whatever brand fan clutch your using works fine for you, and if so I wish I would have known about it.
I have a 5.7 vortec with matching GM Fan clutch and fan from 1998 GM pickup-SUV, custom fan shroud and stock type 4 core radiator on my FJ60, has worked well, best solution I've found. Engine is stock except no emissions, stock fan clutch / fan.... never boiled over/overheated. A/C too.
I would why not they come with the engine package. Its not a race car
Because they are heavy, bulky, restrictive, makes it harder to configure the system, makes for worse fuel economy, etc. FIRST thing you do to build a more efficient (both power and fuel economy) system is remove restrictions
Yes 60's are heavy.,bulky amd restrictive also get horrible fuel economy but with engine swap it will help with everything you mentioned.
