Still trying to replace frozen choke cable on the '76 55. Just can't seem to access the back nut to get the pull mechanism out. Research says remove gauge panel and then remove the choke pull assembly. But How do I remove that gauge cluster? it is now unbolted and wedged between steering column and dash opening won't come out and won't go back in as panel is stuck now.
What am I missing here? speedo cable is off. (it wasn't really clipped on, PO apparently tried to remove panel and couldn't.) Is there a trick to this procedure? I see a lot of gauge panels for sale so somebody knows how to remove the darn thing!
