great job man keep it up!!!
you reno boys going to be at the 4wd convention in the middle of Feb?
Dylan
Dylan
No kidding? You didn't need to heat the bolts to bend them?
Go figure, a scrawny guy like you could do that.![]()
Dylan
Nope,
No heat required!!!
For the record, I did put on some holiday weight when I went home to Chicago...I shot up to 240lbs from 236lbs!!!![]()
I gained it all in my THIGHS!!!
Chicago
The brake line bracket on top of the pumpkin is SCARY CLOSE to the u bolt plate...Is this right? Have any of you had any problems with this, and or done soemthing different?
I ground down the side of the bracket, in hopes that it will stay clear, but Im worried about when the suspension cycles...
Take a look!
You shouldn't have any problems with the brakeline, it will move right along with your u-bolt plate, if there is much movement between the two you have bigger problems![]()
Shheeaa.....You light weight....I clockin in at 140.
I know, I know...Im skinny and need to take more weight gainer.![]()
Im not a FAT guy though...At least I dont think...
Here's a pic of me and my beautiful wife last June for our engagement pics...
Chicago
How did you bamboozle a cutie like that into hooking up with you?
oops sorry saw it just now on page three. Still what have others done. I have 700R4 front D-shaft is fairly long. Is it neccessary?
