Builds FJ 45 Extended Cab Custom Vehicle Build Finally Begins (3 Viewers)
awesome!
Entering the Rock Pit at my place.
Sorry that my phone died last light Dan.
Go add a leaf to your spring pack :)
I called Kurt at Cruiser Outfitters and talked Spring rates.
I took the CS 003 spring off the Beagle Chariot..........
..............and cut apart the flattened out springs. I cut the second from the main down and added it it as a 3rd from the top spring. I also slid in an extra 3rd from the bottom spring.
Bump stop looks real good.
So you are running OME lift springs now? Your lift looks about right as does the travel to the stop. Any pics of the truck as it sits from the side?
I'm curious as the build progresses on my FJ60.
Good thread.
Steering rods still have enough clearance, even when turned?
attachment.php
ToyotaDon
That rust colored piece of metal you are seeing under my steering arm is actually the spring plate.
The space between the top of the spring pack and the steering arm is 3/8" less than it was before adding the two leafs.
I will let you know if it rubs next sunday night.
