NeverGiveUpYota
Dare me.
Looks good. Go with it and tell us how it works.
That would work just fine. Go for it
You're in HAC territory, so you can check if the HAC system is working correctly. If it's not, the engine runs rich and the timing will be retarded. Make sure that the hose and filter on the bottom of the HAC valve are clear. It needs to suck air up through that dangling hose.
One thing's for certain, you don't have a vacuum leak!
I assume the air filter element is squeaky clean as you just had the engine all apart.
Finally bit the bullet and found a smoking deal on a Lincoln welder. Ended up ordering a Easy-MIG 180C from Amazon that was on sale for $495! Best part was that I already had a $70 giftcard balance AND it had free shipping. Should be here Monday next week, which brings me to my next adventure.
so back before i moved from IN to CO the 60 got 12mpg. Jim's carb and dizzy with a fresh rebuilt motor. Now at elevation with the HAC hooked up I'm starting to look at a new mpg. GJ is at 4500. Will update you with new numbers after I fill up.
I recently discovered the same thing on my carb. The diaphragm that operates the secondary is all dry and cracked. I tried to fix it by smearing it with silicon to fill in the cracks but I think it's too creased. Cruiseroutfitters is the only place I've found that sells the 81-87 diaphragm, but it's $32.50 for aftermarket or $57.50 for oem.Ok so little man has been sleeping and I ran out to check my secondary on he carb. Last week I put a paper clip on the arm to test and see if the it was working. After about 4 days of city driving and today driving 60 miles of hwy it IS NOT working. Looks like I got some carb troubleshooting to do.
