Engine Block Drain Plug Help (9 Viewers)
How deep is your hole? You want to work it going up.
Work slowly in and around. Try and go up once you are in like 1/2" or so.
Remember that guy that drilled out the plug in cylinder head - went threw the cooling jacket into the intake port - Moral work slowly and carefully if you aren't sure of what you are doing. Power tools can ruin things quickly - if you just use hand power less chance of damage. But one of my favorite saying is SOME FOLKS COULD RUIN AN ANVIL WITH A RUBBER MALLET.
Update! I seem to have made some progress. When I insert and go to the right, the attachment on my drill goes right through so I can only assume I have worked through that blockage, but on the left side I am still hitting some resistance. Likely because I am limited with space and its hard to maneuver with my drill on that side. Since I seem to have broken through on the right side, should I assume that fluid should be coming through?
you should have had fluid coming through a long time ago. can you start the engine, maybe build up a little pressure for the coolant? and keep digging
Hey guys, so I worked on getting the block unclogged today. I picked, drilled, used compressed air, hammered, started it and let in run for about 5 min. I got one drip out of it:mad: Anyways, is there a chance more than one of the water jackets is plugged?
