It was you haha!
Yup! And I’ve never been happier about a bunch of coolant spilling all over my floor.It was you haha!
After the heater it goes up to the water pump along the passenger side of the blockPig, I thought it came back into the block on pass side.
you should have had fluid coming through a long time ago. can you start the engine, maybe build up a little pressure for the coolant? and keep diggingSince I seem to have broken through on the right side, should I assume that fluid should be coming through?
I probably would, if I knew how.Just pull the engine, rebuild it.
This worked the best for me! it seems like i got the right side of hole open.Chuck up a short section of a steel fish tape in your drill, spin that mug in there and ream that crap out.
gonna give this shot tomorrowyou should have had fluid coming through a long time ago. can you start the engine, maybe build up a little pressure for the coolant? and keep digging
I will give it a shot tomorrow! Its such a tight spot, tough to clear out the left sideUp and towards the front.
