Scrambling to make progress... Rains are coming this week. Still have the oil pan (I ran out of TOY103 seal packing goop), battery tray/battery. Gotta wire in the new fusible link I got from Georg, put on the clutch cover and adjust the valves. Then drive it to the California Smog shop and say a pray to the car gods.
Put on all new rubber O gaskets on the AC lines for the new compressor/new condenser. Green = New, Black = Old. I broke one of the brand new bolts going in to tight so I had to break out the tap and rethread. Luckily the old bolts were in good shape so I just reused one of those.
I used Thread Sealer on all of the AC connections. Seamed like the right thing to do...
Look at all this new!
Belts are on and all snugged up.
Don't give me guff about the Fram filter. It's only going to run for an hour with the first batch of oil. Once it's ran I'm going to dump the new oil for new new oil.
I just ordered the gasket and O ring for the oil cooler. Debating doing that now as well. It never ends!!!! I may wait for the next oil change.
The new cut shroud is awesome. Not sure why I waited so long to do this as I've had the rad out like 5 times before. The riveted tabs worked perfect to help guide the top in place.
New CSF 2708 Radiator. Dropped right in with no mods needed. I did need to use the old rubber rounds for the mounts.
@NeverGiveUpYota You got one of these propane heaters? I can't imagine turning the wrench where you live this time of year.
The shroud has a slight pink hue as I got some overspray on it from painting a bunch of the other stuff red. Just a bunch of speckles. Oh well...
