'91 1HDT, GTX3071R, maxed standard 12mm pump (only for another couple of weeks
), XXi w2a intercooler, 3" straight exhaust, EGT probe is right behind the turbo flange on the dump pipe, 17:1 AFR prespool, 23:1 AFR at full boost, currently running 24psi (1.65 bar), EGT's never go over 400*C in 40 deg ambient temps, even 5th gear flat up hill (manual trans). More boost without increasing fuel will drop EGT's and raise AFR, when I bought the car, the old wastegate was jammed, as a result, when the fuel was turned up it made 32psi @ 30:1 AFR, but wouldn't go over 380*C, also had less power thanks to the lean fuelling. Will be interesting to see the changes in EGT once the new (12mm high flowed) pump goes on, will be running 17:1 AFR right through at 28psi (1.93 bar) or so for the power setting, and 33psi (2.27 bar) at 23:1 AFR or so for daily drive/towing
