LinkBack (7) Thread Tools Display Modes
Old 03-29-09, 03:12 PM   1 links from elsewhere to this Post. Click to view. #121 (permalink)
bsmith123's Avatar
progress
One step forward and two steps back sometimes
I had a bit of a snafu when I had the whole thing back together and running I discovered I had put the throwout bearing in the wrong way round. Having looked at others since it is pretty obvious but the style I got was pretty flat both sides.
On top of that the oil pan leaked in the rear. I saw oil dripping down and my first thought was ---OH not the new rear main! but I thought I saw it coming out the right rear corner of the pan but after some tweaking it seemed to stop. After looking closer I thought I might have torn it putting a bolt through
Okay some heartache but tranny out and tranny in and new oil pan gasket and everything tight as a drum and dry as a bone!
Happy days!
I had hoped to salvage the gas tank but wound up with some rust in my new carb inlet and it wouldnt let gas in, the float dropped but the needle stuck--got that cleared out sucking on the carb inlet. so now new gas tank, filter and lines are on hand and next on the agenda.
to get the tranny out I had to remove the tunnel cover, seat frame and seats, and the header first header pipe following the headers to get to the motor mount. removed the rear mounts and put a tall sawhorse i built to rest the tub on in the tub and used a couple ratchet straps to hold the tranny.
I ran the engine for a good while till she was all warmed up and then tried out the clutch cause the driveshafts are out, 4 wheel drive works and all the gears and reverse and the clutch engages and disengages with no weird noises and feels good
I was gonna move the slave to the right but I will leave that for another day as I am not much in the mood for sorting out any new self induced problems at the moment!
So back up and running where i was a few weeks back but feeling good cause I know this next weekend will be a garage cleanup, fuel system install and put the interior back in. Then the driveshafts. I got the shafts lengthened at a local hot rod shop and they have the old bolt pattern on one end and the new on the other to mate up with the 79 drivetrain. at $270 bucks for the 2 I am going to look into cheaper options for spares. I will just have to be nice to them in the meantime.
Could be a test drive up and down the driveway???? That would make it all worthwhile!
So no pics or anything pretty to look at till next time just the news that she is running again
B Smith123
Haste maketh waste.
When the sun shineth, make hay.
Look ere ye leap.
John Heywood 1497-1580
71 FJ frame off build "UGLY BETTY" http://forum.ih8mud.com/40-55-series...y-betty-5.html
33 in BFGs, 4 inch HFS lift, Durabak, Paki Khaki top, Now sportin a RUNNING 2F and 4 speed!
bsmith123 is offline   Reply With Quote
Old 04-05-09, 03:57 PM   #122 (permalink)
My71FJ40's Avatar
TLCA# 0123456789
All very nice! Can't wait so see the final project....well its never truley done right!?
My71FJ40 is offline   Reply With Quote
Old 04-05-09, 09:49 PM   #123 (permalink)
sls019's Avatar
TLCA# 19741
Well, your build is coming along nicely. Are you going to continue to call her 'ugly'? I really like the way your tub turned out using the durabak. My tub has some pitting on the floors. Would the durabak possibly feel or mask the pits?
MY 71 buildup: http://forum.ih8mud.com/40-55-series...ld-pieces.html
____________________________________
71 FJ40 - 350 sbc, 4" lift, 35" tires, 2nd rebuild
95 TACOMA SR5 V6 4x4 - future Lexus V8 swap
sls019 is offline   Reply With Quote
Old 04-05-09, 10:02 PM   #124 (permalink)
bsmith123's Avatar
pitting
The only change I would make is to use the smooth duraback cause the rough is pretty rough I'll have to put a mat in the back for the dogs---but things wont slide around anyway. I have heard that painting the smooth over the rough takes care of hat though
yes the durabak will cover any pitting it is very textured. POR is quite good at it too--I had a small area of pitting in a corner by the drivers side but it wasnt very deep and the por filled it nicely
Got the new tank in it today but my rear heater core started leaking so I pulled that and was too lazy to take any pics
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-05-09, 10:15 PM   #125 (permalink)
sls019's Avatar
TLCA# 19741
What prep work did you do to the pitted area before coating? Did you just follow the process in your thread on the durabak application?
Old 04-06-09, 12:29 AM   #126 (permalink)
bsmith123's Avatar
prep
Well by the time I used the duraback I had already taken it down to metal, POR 15 metal prep, Aqua clean, then POR-15, then POR 15 top coat primer, then single stage polyurethane, then sanded the poly and applied the Durabakl
I suppose If I hadnt done all that I would at least use the acid and maybe cover the pitting with some zinc chromate primer then just DURABAK it per the instructions
OSPHO acid at ACE hardware will do the same as metal prep I put it on let it do its stuff then clean it off with a 3M paint and rust stripping wheel
my pitting was localized and not deep if it were bad enough to be a strength issue I'd of cut it out and welded in a patch
i am thinking a coat of epoxy primer would not be a bad thing either but I would check the Durabak instructions. I am pretty sure that stuff will stick to just about anything though but if you miss a little spot the primer would keep it protected especially in the corners and seams---Or POR 15 for that matter
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-07-09, 01:30 PM   #127 (permalink)
sls019's Avatar
TLCA# 19741
Thanks for those tips. My tub has light pitting but not enough to harm the structural integrity. This process you have done will help me when i repair my tub this summer.
Old 04-09-09, 03:10 PM   #128 (permalink)
bsmith123's Avatar
She drove under her own power!
Today is the day!
Ugly Betty drove around the block today under her own power. fortunately none of the neighbors were out when I did it! Clutch and brakes feel good, engine is good and the tranny went through all the gears fine.
Steering slop is horrible I'll have to look at that but it was great to have her move under her own power for the first time in over a year!
The pics show the new gas tank I got from SOR. Today I threw the drive shaft in and serviced up the tranny and xfer case and while I was at it I installed the bypass hose. my rear heater spring a leak after reinstalling the seats, it had been fine through the initial engine runs but I thik it may have got jostled around a bit putting in the tank and seat frame and it was delicate. For the time being I looped the hose and I think I am just going to cap it off until I move
still a bunch of stuff to do and I am trying to decide if I should take the plunge on the bodywork and paint or just get everything working and put back together for shipping to the UK in June when we move
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-11-09, 11:42 AM   #129 (permalink)
Mudbug81's Avatar
Sprinkler Man
Looks like you have come a long way. Just goes to show, with the time and money you can make anything great. Keep up the good work. Check out My Photo Gallery below for pictures of my rigs.
It was nice talking with a fellow cruiser head yesterday.
Tim
____________________________________________
1978 Toyota FJ40 No Body
1981 Toyota FJ40 NZ " WRNGWAY "
1998 Dodge Ram Stock
My Photo Gallery
Man who stand on hill with mouth open will wait long time for roast duck to drop in.
Confucius, BC 551 - 479
Mudbug81 is offline   Reply With Quote
Old 04-11-09, 05:15 PM   #130 (permalink)
Nice build. I'm diggin the camo dash
Ted
TRoss is offline   Reply With Quote
Old 04-11-09, 06:26 PM   #131 (permalink)
bsmith123's Avatar
mudbug
What a coincidence eh? Man that Aussie 40 looks good! I should of asked ---who's your shipper? I got send mine to the UK
It's great the interior is so complete
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-11-09, 06:31 PM   #132 (permalink)
bsmith123's Avatar
thanks
thanks, some of the best ideas come from laziness I was so tired of sanding at that point and the paint job I did was going to need some rubbing out to flatten it.
I am going to do the center console and a storage box across the back of the seats with the same stuff, then that's it dont want to get carried away with it
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-11-09, 06:46 PM   #133 (permalink)
bsmith123's Avatar
lights
began working on the lights today and got power to the headlight and turn signals. Coolermans schematics came in handy ---easier to read than my old beaten up FSM!
The headlights had no power at first so I shot the switch and it read power sometimes/sometimes not ---ran a wire from the power side of the fuse to the dimmer and got lights.
Cleaned up the fuse connection with some sandpaper and presto
Only had one turn signal hooked up and it worked with the headlamps as a marker light and the turn signal relay would try to throw with the turn switch but, it would just clunk once and quit --I figure it needs the other lights to put enough load on to make it work--bi metallic switch and all
Toying with the idea of installing a little junction box in the rear to split up the power for the rear combi lights and side lights and I may separate the brake circuit ala Coolerman style since I will need amber turn signals when I get to the UK. So the rear combis will be markers and brakes with OEM side and aftermarket rear amber turn signals till I get back. Prolly just stick em on the bumper.
The wiring for the lights has been previously molested with some speaker wire, solder and press clip splices which I do not like. With the junction box I can put round terminals on and run wires to each light off the block. Some heat shrink over the terminals and some silicone over the screws and mount it underneath somewhere. Should work out nice and neat I think.
With company in town I am only doing a little here and there
Got the kit for the w/s washer from SOR and found the old mount and it fit right on there--good! didnt really like the little flat mount that came with it. The OEM is nicer
Also got my windshield wiper stuff in so I am praying the motors work!
I'll try and get some pics of the lighting set up in the rear and the w/s wiper kit install ---prolly a few folks needing that
nothing like driving it to stoke you to get alll the little junk done!
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-11-09, 08:12 PM   #134 (permalink)
Mudbug81's Avatar
yea i think i really lucked out but i won't know for sure till it gets here. The seller used his shipping company, the company is Wallenius Wilhelmsen Logistics. You might be able to ship yours out on the same boat mine is coming in on. The ship is scheduled to leave Savanna, Ga. on May 25 and arrive in South Hampton, UK on June 16.
Tim
My Photo Gallery
Old 04-26-09, 05:16 PM   #135 (permalink)
bsmith123's Avatar
clip for e brake
Romey look at what I found
http://forum.ih8mud.com/newreply.php...reply&t=204950
will get it off in the mail along with the input shaft coupler
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-26-09, 05:48 PM   #136 (permalink)
bsmith123's Avatar
progress
well I have been chasing wires and getting the wipers, washers, lights, and so on working--not installed yet cause I am refurbishing the light assys a little as I go but progress
got the twist fasteners and grommets for my top so I installed that
as you see the rattle can olive paint is a go at least until I get it shipped in July--just running out of time for that pretty white paint job, oh well gives me a project when I move
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 04-26-09, 05:51 PM   #137 (permalink)
bsmith123's Avatar
progress
of course its da rims that add all the bling
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 05-02-09, 08:42 PM   #138 (permalink)
bsmith123's Avatar
progress
Wow seems like I hardly ever post anymore cause there are so many time consuming little jobs--no one really wants to see the clamp I installed or the grommet I replaced I am sure
But getting the grill and fenders back on today felt and looked like progress--well not all the way on yet but tacked in place anyway.
Now where did I put those rubber apron stops I bought 8 months ago?
Also got new OEM turn signals and lic plate light and reverse light
and installed a set of ROUNDEYES which I think look pretty cool!
trying to get it bolted up to ship out some time in late may early June--I will have to start working most weeknights I guess
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 05-02-09, 08:43 PM   #139 (permalink)
bsmith123's Avatar
pics
a couple of the new lights
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 05-03-09, 06:10 AM   #140 (permalink)
tmarx's Avatar
Looking good. Keep it up
Theo
105 1HZT I/C
BJ 42 LX 11/83 - 3b H55F P/S 3 wipers and slidin windas
tmarx is offline   Reply With Quote
Old 05-06-09, 01:53 AM   #141 (permalink)
lostmarbles's Avatar
x 2
(Just gone through this whole thread in my spare time over the last few days.)
Name's really Tom & I have a 1979 Australian-market BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A tire is really a tyre...........
lostmarbles is offline   Reply With Quote
Old 05-06-09, 10:03 AM   #142 (permalink)
sls019's Avatar
TLCA# 19741
Rig is looking more and more complete. I am digging the soft top. Also, those bucket seats are growing on me. Nice set-up!
Old 05-06-09, 10:46 AM   #143 (permalink)
bsmith123's Avatar
thanks
thanks,
I wish I could of done proper paint but that will have to wait till after I move. The seats were a must have I like the original split bench but my back wouldnt put up with no reclining
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 05-06-09, 10:55 AM   #144 (permalink)
sls019's Avatar
TLCA# 19741
Yeah I agree with the reclining. I enjoy a nap in my truck or 40 also. Must get some good recliners! What other changes are required for the UK move?
Old 05-06-09, 01:14 PM   #145 (permalink)
bsmith123's Avatar
right hand drive
well first there is the right hand drive mod ---NO! Just Kidding
Not a lot is required ---just lighting since it has RED Turn Signals I'll need some stick on ambers that I can run from a terminal block and I'll need a red fog light in the rear off a toggle switch and then just readjust the headlights to the other side so I dont blind 0ncoming traffic with my new Roundeyes!
It will also need an MOT inspection which is just and annual vehicle safety inspection, brakes, steering, lights and and so on
I think this will even be exempt from Roaf Tax over there as a classic vehicle---woo hoo! Watch out Land Rovers
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 05-30-09, 08:10 PM   #146 (permalink)
bsmith123's Avatar
winch
Got the winch bolted up
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 05-30-09, 08:34 PM   #147 (permalink)
jsuthey's Avatar
TLCA# 7702
Looking really good B.Smith,nice work! Classic warn 8274,I am digging that winch! Good luck with the move,where are you going ?
SOLD!!!93 FZJ80 Rubicon Ready
98 T-100 EXT. CAB 4WD,
2000 FOURUNNER LIMITED 4WD
69 FJ40-Rattle can restoration in progress!! 71 F,stock 3-sp.&TC(floor shift conversion on both)
4" Rancho lift(LC Adv.handling SR)Man-a-fre disc brk.front& ss lines,BFG MUDS 33x12.50-15's,Kayline soft top.
jsuthey is offline   Reply With Quote
Old 05-30-09, 10:11 PM   #148 (permalink)
bsmith123's Avatar
move
Going to the UK, I'll be there for about 5 years this time.
The 40 is going on a ship the third week in June---have to finish the bolting up by then!
B Smith123
Haste maketh waste.
Look ere ye leap.
Old 06-07-09, 11:03 AM   #149 (permalink)
Mudbug81's Avatar
Good luck getting all the shipping stickers off the window once it gets there. Mine have been a real pain.
Seeing your paki top on there makes me want one really bad.
Tim
My Photo Gallery
Old 06-07-09, 07:11 PM   #150 (permalink)
bsmith123's Avatar
Bon voyage betty
Well the truck showed up early by 2 weeks to pick up Betty, I was tempted to keep her here and call the company but I knew the trucker would lose out and leave empty and it wasnt his fault
So I scrambled and got it together tying up loose end best I could before she went--lucky my door hinges and drive shaft nuts showed up when they did.
So as far as the build goes I almost got there but not quite so a little left to do when I get over to the UK and I am disappointed that I had to do a rattle can job instead of a real paint but I ran out of time
Doing the bodywork and paint wont be too bad but I am not looking forward to the windshield install for the second time
So here's the final pics of Betty just before her voyage to Felixstowe port in the UK
B Smith123
Haste maketh waste.
Look ere ye leap.
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/204950-71-fj-build-ugly-betty.html
Posted By For Type Date
Any help looking for tracks in/near thetford This thread Refback 07-09-09 12:20 PM
Newbie--My 71FJ40 This thread Refback 06-08-09 09:37 PM
Vacuum advance hooked up directly to manifold....is this bad????? This thread Refback 05-06-09 08:41 PM
looking for someone to MIG weld some small rust spots on the FJ40's TUB This thread Refback 04-03-09 08:16 PM
my build 71 Fj 40 This thread Refback 10-15-08 12:31 AM
Emerald Coast Off Roaders :: View topic - FJ 40 resto This thread Refback 05-21-08 08:36 PM
Emerald Coast Off Roaders :: View topic - FJ 40 resto This thread Refback 05-19-08 08:44 PM
