Is the washer the same as what @ff347 posted? This is my new leading theory. Too much axial play lets the lever grab too many pawls.
FWIW I saw no washer in there when I did the work. Neither side. It's also not on the parts diagram, though...
The 'Washer' is in the parts diagram (it's a 'C' style clip).
I don't know if this means anything or not: Looking in the EPC, there are TWO different part #s for that washer covering 81-92 60-series, all world models FJ6x BJ6x, HJ6x ! The TWO different numbers are listed as having different sizes (thickness); A 1.2mm and a 1.6mm ! But there's no application differentiation, so it seems the different thickness perhaps are a kind of shim for adjustment/compensation ?
And something else I didn't now, it looks like the adjusters changed in 9/84, where the Diameter of the adjusting wheel or shaft (can't quite tell from schematic) changed from 10mm to 12mm... I don't see any differentiation in aftermarket adjusters...
So the answer may just be a difference in thickness of that washer, as you stated, it's a shim. A generic washer like @ff347 might just do the trick! It would make sense, adjusting where the 'finger' of the adjusting lever hits the star-wheel would affect the number of degrees of 'turn' it would make... ?
@ToyotaMatt Where you at, bruddah?
So this has me stumped. I rebuilt the drum brakes on my 60 about three weeks ago. I did one side at a time so that I could use the other side as a cheat sheet and not misplace stuff. I took the drums off at Solid Axle Summit and had a bunch of knowledgeable cruiser heads verify that I did the installation correctly, including people who run Land Cruiser specific shops ... but they are over adjusting themselves. The drums and backing plate get pretty darn hot, right on the verge of not being able to keep your hand on them. Every few days I back the star wheels off again, so I'm dealing with it, but that's less than ideal.
Details:
Reused 140k mile drums as they looked great
New shoes - cruiser outfitters
New springs & hardware kit - cruiser outfitters
New Advics wheel cylinders - cruiser outfitters
New bell crank bracket and boot - OEM
New bolts for bell crank bracket and wheel cylinder - OEM
Napa Sil-glyde silicone-based brake grease on moving parts and contact points of backing plate, per FSM
Copper hi-temp anti-seize on bell crank moving parts and pins
All reused parts - mainly the linkages and adjuster/star wheel assembly were cleaned 100% and lubed where the parts slide against each other or otherwise make contact. So the way these brakes work is that pulling the hand brake adjusts the shoe tightness to compensate for wear. At a certain point the hand brake should not adjust the star wheel any more, but apparently it still is. Despite some people saying so, I do not see a way these brakes could adjust themselves by going in reverse - there's no mechanism for that to happen. Maybe that's a 62 thing. I've adjusted and lubed the hand brake linkages as well as the end slack of the cable at the hand brake itself.
The brakes are still getting hot, and in the past 3-4 days they've started squeaking when I'm coming to a stop. Anybody seen this after a drum brake job? I'm at a loss...
42403B | BOLT, SET (FOR REAR BRAKE DRUM SETTING) |
90113-10003 |
- did you have BOTH drums Machined per the FSM wear limits ?
- did you make DAM DAM sure , to have BOTH / 1 each side , the JIS P3 phillips drum retainer / keeper V-HEAD machine screws in place ,, preferably new ones ......... and secure from on-set of adjust ?
- if either answer is no ?
- then there lies the issue .....
- the YES or NO to being professionally Machined the BIG 1 ?
- if YES ?
- then there is ONLY 1 possible cause ....
42403B BOLT, SET (FOR REAR BRAKE DRUM SETTING) 90113-10003
the semi-floating rear axle shaft does NOT have a deep enough lip to PLUMB LEVEL AND SQUARE up a properly machined drum , let alone a pre-owned one all Katty-Wompus one or both oscillating like they will do average use and stuff ...
The deep-bevel drum fixing bolts were put back appropriately after the job was done.
As for the drums … I rescued mine. 140k miles, they measured in spec per the FSM (can’t recall off the top of my head, but “not greater than 250mm inner diameter” or something) and they measured round. As above, I may buy new OEM drums “just cuz”.
I originally posted about this in 2016 rear brakes over adjusting..... - https://forum.ih8mud.com/threads/rear-brakes-over-adjusting.327957/page-3
I have done several rear brake installs on older Toyotas using the same method without overadjusting issues. They just
don't make things like they used to so even if you order brakes from Toyota, they aren't going to have the tolerances
that they used to. The thickness of the washer and whether you need one at all will depend on each individual case.
Toyota factory parts have taken a nosedive for quite a while now. look at this Toyota factory manifold this guy just got
straight from the dealer RockGoat Version 3RZ - https://forum.ih8mud.com/threads/rockgoat-version-3rz.1310912/page-4#post-15070033
@liveoak I did read that thread but just read the whole thing again. I think you guys were right on the money way back when - I really think to much in/out play in the lever allows it to grab the star wheel when it’s not supposed to. I’ll get some washers and get into the drums sometime this coming week.
Today was a good day and I did not need the parking brake so no worries.
It works so It heals itself, like an oil leak.
and yesterday also no need for parking brake , a miracle.
A lot to check when we get home, all makes sense so thanks for the knowledge.
