Builds DIY FJZ80 Low Budget Turbo Build (2 Viewers)
Blacked out the front end
Is there a single pic in this thread showing the Turbo setup?
I kinda meant with complete hardpiping installed. I'm guessing it's not done yet. I will check back to see how it all turns out. Good luck with the build
I saw your build first on the other forums. You will get way more info from there and most of the parts used for cheap. I would almost guess that a oem 2j fuel pump would drop in as well as some n/a or TT injectors
Giddyup :D
:popcorn:
cool, sounds abit 1j, is it full stainless? keen to see some flybys once the pipes are carbon'd up. cant wait to get mine done.
And for reference, here is a dyno pull from my truck while stock. (153hp/219tq) Good baseline to compare with the turbo swap. The other pull on the chart is an overlay of my car I dynoed the same day.
Stock Cruiser Dyno
I'm curious why your HP is low at 153hp- is that due to the usual 30% driveline loss?
