Here is my most up to date "To Do List":
Completed Items:
✓- Replaced missing ARB bumper decals (ARB sent as a courtesy)
✓- Cubby storage tray for cooler console (From Amazon)
✓- OEM shift knob (Toyota Part No. 33504-60241-E0)
✓- OEM floor mats (Toyota Part No. PT206-60080-01)
✓- OEM carpet cargo mat (Toyota Part No. PT206-60084-01)
✓- Installed Midland GMRS radio and ghost antenna
✓- Installed front license plate onto bumper
✓- Applied Fluid Film to front and rear bumpers
✓- Removed aftermarket side steps
✓- Used penetrating oil to loosen KDSS valves
✓- Removed aftermarket window tint on front windows and windshield
✓- Replaced missing center headrest for third row (thanks to a very kind MUD member)
✓- Set up iPhone: Bluetooth for calls, dash mount, charging cable, and music through auxiliary input
✓- Check front end components for wear: wheel bearings, CVs, tie rods, lower control arms, steering rack
✓- 275/70r18 BFG KO2 Tires
✓- Installed new OEM LCAs and hardware
- Toyota Part No. 4806960030 $ 276.25 Suspension Control Arm (Left, Front, Lower)
- Toyota Part No. 4806860030 $ 276.25 Suspension Control Arm (Right, Front, Lower)
- Toyota Part No. 9011918006 x 2 $ 8.59 Alignment Camber Adjusting Eccentric Bolt
- Toyota Part No. 481900C020 x 2 $ 22.33 CAM ASSEMBLY, CAMBER ADJUST
- Toyota Part No. 481980C020 x 2 $ 11.25 Alignment Camber Adjusting Eccentric (Left, Right, Front)
- Toyota Part No. 484520C020 x 2 $ 20.35 Alignment Camber Adjusting Eccentric (Front)
- Toyota Part No. 484090C020 x 2 $ 16.64 CAM SUB-ASSEMBLY, FRONT SUSPENSION TOE ADJUST
✓- Replaced OEM PCV valve (Toyota Part No. 12204-38010)
✓- Replaced Actuator Assembly for transfer case (Toyota Part No. 36410-60112)
✓- Replaced ARB bumper fog light bulbs (H3 w/bullet connectors)
✓- Replaced Door Belt Moulding for all windows (Toyota Part No. 75720-60070, 75710-60070, 75740-60050, 75730-60050)
✓- New OEM Truestart 27F flooded lead acid battery (Toyota Part No. 00544-27F60-710)
✓- Oil change 5w-30 09/07/22
✓- Installed 2" Old Man Emu lift
✓- Lubricated steering shaft ingress and egress at firewall using silicon lubricant spray (Fixed squeak from steering wheel that started happening while parallel parking)
- Installed new clock spring to fix issue with intermittent Cruise Control - (Toyota Part No. 84306-0E010)
- Installed ARB front recovery points (ARB2815020)
✓- Installed BudBuilt sliders
✓- Installed Bud Built skid plate set
✓- Installed new OEM Transfer Position Switch (Toyota Part No. 84223-60010)
✓- Installed Warn EVO 10s Winch
✓ - Installed OEM wiper blades (Made in Japan versions- Toyota Part No. 85222-53071 (Front, Right), 85222-42110 (Front, Left), 85242-42030 (rear)
✓- Cleaned sunroof drains
Immediate to do list:
- Grease the drive shafts
- Apply Fluid Film to inside and outside of frame rails
- Cabin air filter
- Repair HVAC recirculate flap
- Diff fluids
- Transfer case fluid
- Transmission fluid
- Spark plugs
- Coils
To do soon list:
- Replace 2 main oxygen sensors
- New OEM headlights (Right- Toyota Part No. 81130-60D33, Left- Toyota Part No. 81170-60D03)
- Refinish ARB bumpers (rust treatment, dent removal?, repaint, drill holes for rear parking sensors)
- Replace front bumper rubber "Buffers" (ARB Part No. 3163018R, ARB Part No. 3163018L)
- Replace front bumper fog light surrounds (ARB Part No. 3163015)
To do someday/possibly maybe list:
- ARB Roof Rack
- 17" wheels and 34" tires
- Harrop Eaton ELocker
- Nitro 4.88 gears
