Definitive led thread for 80s (6 Viewers)
This thread is pretty cool. I appreciate what LEDs bring to the table and while I don't want EVERYTHING to be LED, I do want most of my lights to be replaced. Thank you for such a well documented job.
I may have gone a little overboard with the LEDs but some like their 80 to look like a 7-11 in Reno. :grinpimp:
Dude. You need help!!! Lol. Forget the 7-11. Your truck is gonna look like the Vegas strip!!! I likey!!!
Just ordered mine
Mods,
Can you sticky this thread / add to FAQ?
I see a lot of inquiries ab dash and/or led interior lights.
Probably been answered numerous times. Has anyone any luck with the factory dimmer after replacing with LED in instrument cluster ?
I have swapped in several bulbs and all have dimmed. The key is finding ones that put out the same light as everything else.
Hmmmm that's nice and all but the one that came stock has alarm and timer. Nor really necessary but I use at least once a month. Guess just gonna have to do research and modding.
LEDs:
Shift Indicator
(1)Type B - green------------------------------------------------autolumination - Neowedge Item # Single Led Type B Blue 2.99
(9)Type B - white------------------------------------------------autolumination - Neowedge Item # Single Led Type B Super White 2.99
Turn Signal Indicators
(2)194 - white---------------------------------------------------autolumination - T10 Wedge Item # Superstar W/Heatsink Super White 7.99
Gas empty
(1)194 - white---------------------------------------------------autolumination - T10 Wedge Item # Superstar W/Heatsink Super White 7.99
Cluster
(4)194 - green---------------------------------------------------autolumination - T10 Wedge Item # Superstar W/Heatsink Blue 7.99
(18)Type 74 - white----------------------------------------------autolumination - 74 Item # Superstar Led Super White 2.99
(3)Twistlock bases needed to add bulbs to non-us holes------------autolumination - Twist Lock Item # 74 .29
Defrost
(1)Type B - white------------------------------------------------autolumination - Neowedge Item # Single Led Type B Super White 2.99
(1)Type B - amber-----------------------------------------------autolumination - Neowedge Item # Single Led Type B Red 2.99
Rear Heater
(1)3mm Green LED (soldered)---------------------------------------superbrightleds - RL3-B2030 Blue 3mm LED $ 0.63
(1)3mm Amber LED (soldered)---------------------------------------superbrightleds - RL3-R5030 Red 3mm LED $ 0.60
Hazard
(1)Type B - white--------------------------------------------------autolumination - Neowedge Item # Single Led Type B Red 2.99
Antenna
(1)Type A - white--------------------------------------------------autolumination - Neowedge Item # Single Led Type A Blue 2.99
PWR/2ND
(2)3mm Green LED (soldered)---------------------------------------superbrightleds - RL3-B2030 Blue 3mm LED $ 0.63
CenterDiff
(1)Type B - white---------------------------------------------------autolumination - Neowedge Item # Single Led Type B Super White 2.99
Security
(1)5mm squared off LED (soldered)
Heater
(3)Type B - green--------------------------------------------------autolumination - Neowedge Item # Single Led Type B Blue 2.99
(12)3mm green LED (soldered)--------------------------------------superbrightleds - RL3-B2030 Blue 3mm LED $ 0.63
(2) 3mm amber LED (soldered)--------------------------------------superbrightleds - RL3-R5030 Red 3mm LED $ 0.60
CigLighter ring
(1)Type B - green - removed from base (soldered)-------------------autolumination - Neowedge Item # Single Led Type B Blue 2.99
Floor Shifter
(1)Type 74 - green-------------------------------------------------autolumination - 74 Item # Superstar Led Blue 2.99
Key Ring
GloveBox
(1)Type 74 - white-------------------------------------------------autolumination - 74 Item # Tri-Power Super White 3.99
AshTray
(1)Type 74 - white-------------------------------------------------autolumination - 74 Item # Superstar Led Blue 2.99
Visor/Vanity light
(2)31mmX5mm fuse looking thing-----------------------------------autolumination - Festoon Bulb Item # 3 Led Super White 7.99
MapLight
(1)Ba9 - white------------------------------------------------------autolumination - Bayonet Item # 48 Led SMT Array Cool White 24.99
You may need to reverse the red and black wires. Take them out of the plug and swap.
DomeLight
(2)31mm festoon----------------------------------------------------autolumination - Bayonet Item # 48 Led SMT Array Cool White 24.99
Courtesy Lights
(4)194 - white------------------------------------------------------superbrightleds - WLED-x5 LED Wide Angle LED bulb $ 2.99 (each) - Cool White WLED-CW5 0.95
License Plate
(2)168/194 - white-------------------------------------------------autolumination - T10 Wedge Item # Supernova Super White 7.99
Window Switch
(1)3mm green LED (soldered)----------------------------------------superbrightleds - RL3-B2030 Blue 3mm LED $ 0.63
Rear Markers
(2)194 - white------------------------------------------------------autolumination - T10 Wedge Item # 4-Star Super White 7.99
JDM Side Markers
(2)194 - amber-----------------------------------------------------superbrightleds - WLED-x5 LED Wide Angle LED bulb $ 2.99 (each) - Amber WLED-A5
Front and Rear Turn Signals
(4)1156 - amber------------------------------------------------------autolumination - Bayonet Item # Eagle Eye Tower 11led $24.00 (each)
Dual Filament 1157 - Front side markers(1157 not stock - only used if you have modified the side markers to flash) stock is a 194 amber
(2)1156 - amber-----------------------------------------------------autolumination - Bayonet
Item # Eagle Eye Tower 11led $ 24.99 (each)
Red Instrument lights - Brake - Diff lock - Airbag - etc. trying red to eliminate the pink looking red caused by LED white bulbs.
(10)Type 74 - red----------------------------------------------autolumination - 74 Item # Superstar Led Red 2.99
Slee Rear Bumper License Light
(1)Ba15s--------------------------------------------------------autolumination - Cool White - G18 Small Head - 15Led Matrix
$9.99
SUPER BRIGHT LEDS - LED Lights & Accessories
www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs
Thanks for this post, i'm undertaking this project!
holy crap, I was literally just thinking, "these new Cree 7w reverse lights are awesome, I wonder what else I can do with LEDs.."
Thank you good sir. :beer::beer::beer:
Thanks to TreerootCO for this thread and everyone's input and updates, I'll be changing all the LED lights on my 1997 lx450...ordering today...minus the soldering...not that DIYer......but hope to learn. I'll post my pics once all is up and running. Thanks again!
Very helpful, thanks!
I replaced most all the LED per the OP. I have one issue: The key ring stays on all the time. When I open the door it goes bright but then it dims to just a glow at the time the incandescent would go off-the incandescent bulb does not do this. It is kinda cool but I am guessing it will drain the battery.
Anyone else have this issue? Or do you think it is related to a 'leak' elsewhere? BTW
Couple of questions to anyone that can help.
Im half way through some dash mods including replacing all the bulbs and its winter here and dark just after 5pm and im sick of driving with no dash lights.
Can someone give me an idea how to remove the dimmer switch from the dash surround so i can plug it back into the loom until im done?
Ive had a galf arsed go at it but dont want to break it.
The other question is im fitting a viper alarm so ive got keyless entry. Woudl a US toyota security light work with the alarm to keep it looking stock?
Mine didnt come with one fitted but im trying to source one
