Might have mentioned this in the past, but while doing Resomat install recently I had to take the front seats out, and I re-discovered the ugliness of the damaged front seat rear outer mounts. They were broken in previous ownership and it would be next to impossible to repair with new original seat mounts (if they're even available).
Here's a pic of one of them (the other front seat rear outer mount is similar):
flickr page
Basically the captive nut has broken away from the piece of formed metal spot-welded to the floor member, meaning that there is nothing for the bolt at this location for both front seats to secure into.
The only solution I've been able to use to date has been a seperate big washer and nylock nut which is extremely difficult (I rate it as a 9 out of 10 on difficulty scale for a very simple problem) to position underneath where the captive nut has broken off when the seat and flooring material are in place. I can do it, but it's really fiddly and annoying.
Has anyone solved this problem another way?
I'm thinking of trying to find (or maybe learn how to make) a 'nutplate' sort of like the stick in an icecream with a nut of the correct thread spec welded to it so it's much easier to install/remove.
Craig.
flickr page
Craig.
