I enjoy going hard when pulling love. Sometimes it yields admiration plus $$$.Um.... what?
"Toyota will go hard you have to have pull love an admiration plus $$$$$$$$"
Yazaki is one of the wire harness suppliers for Toyota. This is electrical tape for the purists.Ok. You posted a pic of a roll of tape. Yes, tape.
It costs between 6-10 bucks for Tesa, 3M, or any other high heat electrical harness tape. What makes this Yazaki tape so special?
I really tired my grammar decoder wheel and diagramming the word clusters and failed.
What idea are you trying to convey?
This gets to the level of absurd puritanism. Are they going to import special Toyota distilled water for the cooling system? Special Japanese R-134 for the AC? Japanese air for the tires? I'm all for OEM when it matters (hoses and belts) but tape? There's not going to be a Pebble Beach with Velocity channel show of boater hatted ment with clipboards going over the wire harness of a 25 year old truck and noting "Ah, obvious change from the 3M to Yazaki here around the #6 cylinder. Dock three points!"Yazaki is one of the wire harness suppliers for Toyota. This is electrical tape for the purists.
Could I have a personal pic sent to my inbox so that I will just have in in case I forget what a roll of tape looks like?1 more pic of the tape please.
I would have called a four point dock, but you are on the right track. I am guilty of falling for this though. I just ordered an OEM fuel filter for my '94 because I am doing the HG and that is the best time to do one. I had an old Wix fuel filter that I ordered for one of my other Toyota trucks about 8 years ago sitting around because it was a PITA to get to. I actually installed it on the truck I am doing the HG on now, but even though it looked the same, the little bracket didn't reach all the way to the inner nut on the intake manifold. No mind that the one that was in there looked indentical as far as filter end of the operation and the fact that the last guy left the inner nut off because it is a PITA to get to without pulling the manifold. My mind raced. "Is it the same inside?", "What if it looks the same on the outside, but a 2RZ-FE might need a special flow rate or something that this Land Cruiser from 3 years earlier doesn't have?" "What if the Wix just lets any old thing traipse into my 1FZ-FE!?"This gets to the level of absurd puritanism. Are they going to import special Toyota distilled water for the cooling system? Special Japanese R-134 for the AC? Japanese air for the tires? I'm all for OEM when it matters (hoses and belts) but tape? There's not going to be a Pebble Beach with Velocity channel show of boater hatted ment with clipboards going over the wire harness of a 25 year old truck and noting "Ah, obvious change from the 3M to Yazaki here around the #6 cylinder. Dock three points!"
The tape cost around 23.00 an is the matching correct color. The other tape for engine harness is nitto no. 223s, check nitto USA.View attachment 1336109 View attachment 1336109 View attachment 1336109 View attachment 1336109 I dont have enough full info. Tape may be supercedeing or continued an discontiened. A new supplier nitto may supply? I will post with wat I know. The more inquiries wit your parts dept creates demand for any part to let you know. We work as a team an for the most part nothing is discontinued. There is other markets that continue an there is demand which will create a part. Toyota will go hard you have to have pull love an admiration plus $$$$$$$$. Lol
The element on aftermarket ones brake down clog up cause restiance. the oem or npn japan would be a better choice far as service life an reliability.I would have called a four point dock, but you are on the right track. I am guilty of falling for this though. I just ordered an OEM fuel filter for my '94 because I am doing the HG and that is the best time to do one. I had an old Wix fuel filter that I ordered for one of my other Toyota trucks about 8 years ago sitting around because it was a PITA to get to. I actually installed it on the truck I am doing the HG on now, but even though it looked the same, the little bracket didn't reach all the way to the inner nut on the intake manifold. No mind that the one that was in there looked indentical as far as filter end of the operation and the fact that the last guy left the inner nut off because it is a PITA to get to without pulling the manifold. My mind raced. "Is it the same inside?", "What if it looks the same on the outside, but a 2RZ-FE might need a special flow rate or something that this Land Cruiser from 3 years earlier doesn't have?" "What if tix just lets any old thing traipse into my 1FZ-FE!?"
"F-it, why take the chance, order the "right" part."
Anyone want a brand new Wix fuel filter?
