- Thread starter
- #21
Try workThis gets to the level of absurd puritanism. Are they going to import special Toyota distilled water for the cooling system? Special Japanese R-134 for the AC? Japanese air for the tires? I'm all for OEM when it matters (hoses and belts) but tape? There's not going to be a Pebble Beach with Velocity channel show of boater hatted ment with clipboards going over the wire harness of a 25 year old truck and noting "Ah, obvious change from the 3M to Yazaki here around the #6 cylinder. Dock three points!"
The water is distilled an from Japan you can purchase direct from Aisian also try autohaus as 18.00 free shipping . Denso 999 0101 for oil for Ac an from Japan , good in all r12 an 134a Denso systems fully compatiable amazon has it. In 3 years 134a will be discontinued china can sale it cheaper then USA can produce it i can get u cans from Japan an mexico r22 cheap if neeneed lol Stay away from stop leak an I Recmond the 134a silva brand straight from Dupont. Transmission fluid from Japan use the nippon eco fluid go in any Toyota transmission aka silk juice. You can use 3m if you wish or masking tape. Far as the tape there's customers who want except that also there liability issues most dealers will try sale you new harness. I just put the info an tape for everyone if interested. 23.00 is nothing for tape if I get 20 years out of it an its correct far as oem approved an spec requirements. Im rebuilding my harness why not use the correct tape especially if your going go buy tesa. I replaced connectors clamps etc. I do clean work. The harness is discontinued I rebuilt my trnafer transmission an engine an I replaced everything new that's what the forum is for good luck man.This gets to the level of absurd puritanism. Are they going to import special Toyota distilled water for the cooling system? Special Japanese R-134 for the AC? Japanese air for the tires? I'm all for OEM when it matters (hoses and belts) but tape? There's not going to be a Pebble Beach with Velocity channel show of boater hatted ment with clipboards going over the wire harness of a 25 year old truck and noting "Ah, obvious change from the 3M to Yazaki here around the #6 cylinder. Dock three points!"
