Awesome! :]
Seems like a 2 bannana job after the cutting is done
To be clear, there aren’t clearance issues with a straight 3 speed for 4 speed swap are there; since you cut a hole for the shifter? My only clearance seemed to come in using the adapter to retain the column shift with the 4 speed. The tunnel only came up by the height of the adapter.Whoa! That's great to hear @red66toy
The days go by so quick and there's so many other things to do. Its hard to find the time. I'm eager to see how your tunnel is coming along!
For the molds, we're you thinking of re-creating a fiberglass or even a stamped steel version of them? It would help out a lot of people, for anyone doing a 4 speed conversion and are having issue with clearance issues.
I don't think there are clearance issues with a straight swap..... But I could be totally wrong.To be clear, there aren’t clearance issues with a straight 3 speed for 4 speed swap are there; since you cut a hole for the shifter? My only clearance seemed to come in using the adapter to retain the column shift with the 4 speed. The tunnel only came up by the height of the adapter.
You guys are right..... But, in my case, something was stopping me from getting the transmission cover on. The biggest issue was having a transfer-case saver. I bought the "heavy-duty" version, which is extra long, and impeeds the top-cover from Sitting flush on the floor. It's only about 0.25 inches of clearance issue, but thats just enough to prevent it from sitting as it should.I don't think there are clearance issues with a straight swap..... But I could be totally wrong.
I appreciate this post in particular, because I have wondered for a while about the interchangeability. Other than the obvious part of cutting off the tail, that’s as much as I figured.Just want to show that this is possibly the fastest way to go about any 4 speed swap as far as getting a taller tunnel. Even more so considering the colum shift adapter. And, it was very easy for someone who doesn't have the talent at welding things very well. I don't know why I waited so long suffering with all the exhaust/engine heat and noise from the road.
I was able to get the tunnel at a discounted "sale price" through cruiser corps, several months ago, plus free shipping.
Edit: anyone wanting to go this route, just pay attention to how the tunnel sits on your floor, mark the tunnel with a sharpie, then make the appropriate cuts. It'll take a few times to get the correct cuts and measurements, but it's stupid easy to do. Easily done in one day (minus welding up the big gap on the passengers side)
That line from Star Trek comes to mind:Finally got done with cutting and welding the transmission hump! Lots of nights with just a little spare time so it took a bit. This was my first real welding project and I think it came out pretty decent!
Next step is to 2k epoxy primer, then a little quality filler, then paint. My lofty/unrealistic goal is to get it done by Tuesday for the local cruiser meeting...
Nice work!Finally got done with cutting and welding the transmission hump! Lots of nights with just a little spare time so it took a bit. This was my first real welding project and I think it came out pretty decent!
