Okay, get your minds out of the gutter! I just finished my roof rack. I looked around on line for one, but I couldn't find one that I liked that was a decent price. I like the SOR and Man-a-fre ones, but they were way out of my price range. So, I welded this one up. I think it turned out pretty good (at least for my amateur welding/fab skills). I made it out of 3/4" square tube and expanded metal for the floor. I used Thule gutter mounts that I bought used for a good price and Thule cross bars. I'm using some small u-bolts to mount it to the cross bars. All told, I'm into for less than $200, which was far less than anything I could find on line with shipping.
My biggest problem is weight. Since I used steel instead of aluminum, the weight of the rack is 55 lbs. So, here's my question. What is the max weight I should put in this thing without distorting or ripping off the gutters? I'm not worried about the rack. It is stout enough to hold as much weight as I can put in it. For the commercial ones, I've seen quotes of 200 lbs max, but that seems like a lot for those gutters? What do you all recommend. I was thinking somewhere around 150 lbs total weight, so maybe 100 lbs of gear. Does that sound reasonable?
Anyway, here's the pictures. Thanks for your help.
