- Joined
- Nov 29, 2007
- Threads
- 26
- Messages
- 473
I see people recommend EZ-Outs (or bolt extractors) frequently, but my personal experience with them is very poor; a success rate of maybe 5%.
And the thing is, when you try the EZ-Out route and it breaks, you have significantly compounded the problem because instead of a relatively soft bolt (easily drill-able) you now have a much harder EZ-Out (non-drillable) to remove. Your options now are very limited.
My first suggestion would be to weld a nut onto the broken bolt. I would then use penetrating oil (and be patient and let it penetrate - that may mean multiple applications over a few days).
Then when you're ready put a wrench on the welded-on nut. I would recommend trying to loosen it first, but if it doesn't cooperate, you might try tightening it and then trying back and forth as you slowly work the bolt out. If you break the weld, not a problem, get another nut and try again. You can combine the welded-nut technique with heating the area around the broken bolt.
If after multiple attempts the bolt just won't come out, you can still drill out the bolt and hopefully chase the threads. Failing that, you can drill out the bolt oversize and put in a Heli-Coil.
Toyota doesn't make them anymore. So I drilled it out, tapped it, and installed a helicoil. Worked like a champ! I burped the system a couple times, cranked it up, and drove it around.
You can only imagine what the wife has been saying ever since the 40 arrived!
It's a shame that it's on the axle housing, I would have preferred to take a small part inside and center the hole on the drill press. Removing the axle is probably a little overkill, though. So… Cut it off with a sawzall? I have an angle grinder, would that be better? (sparks flying up in the engine compartment would kinda suck) Also, do the bolts need to be welded, or can I secure them with nuts/locknuts?
