- Thread starter
- #161
Makes you nervous, I’m likeyour jackstands on gravel makes me nervous! be careful I once had a major accident this way......
When I’m wrenching on it I usually add an extra set under the frame rails or sliders.
I'm seriously shocked.
How could someone get burned from coals being covered by sand? I would imagine the coals would go out in a couple of minutes after being buried in the sand and certainly not last overnight or a few days.
It's not the only idiotic rule I've seen or heard about so I should not really be surprised.
Seal, no. The gasket was weeping but but the oil level was still full. I’m planning on topping it off and ordering a new install kit so I can tear into it when I get back.Hard to tell. I have slammed pinion yokes and ground them on rocks in medieval fashion several times on my cruiser and past rigs without bothering the pinion bearings or differential in any way.
The squeal you describe would indicate oil or grease starvation. Even a diff bearing that’s toast won’t squeal like that if it is well lubed.
Is your pinion seal leaking oil?
If it was a Jeep, I’d agree. See ya on Friday.If your diff is squealing that loudly, I would not drive it.
The u-joints in the CV are toast.What would cause the DC shaft to vibrate so much?
Worn out? Out of balance (off road direct hit)?
I'm running Slee caster plates. My caster is on the low side and I've been thinking about buying his radius arms. But I have a wedding to take care of first. I know, I know....What sort of castor correction have you done?
I also have Slee plates for 4” lift. My front lift is more like 4.5” and my castor is less than 1*.The u-joints in the CV are toast.
I'm running Slee caster plates. My caster is on the low side and I've been thinking about buying his radius arms. But I have a wedding to take care of first. I know, I know....![]()
