Tapage
Club 4X4 Panamá
BOV to atmosphere. No adverse affects to speak of.
Mmmm then you are getting this beauty sound .. at each shift .. damn!
What kind of BOV ( brand ) are you using . ?
Its an OEM Mitsubishi Eclipse version.
Hey, what size is your wastegate?
Looks like I have to replace mine![]()
this thread kinda makes me wanna do a turbo 2FE build... So i guess that would make it a 2FeT?
Way in front of you see link below mines intercooled too
Have fun I am
never even noticed that before!
so did u ever run it w/o a turbo or an intercooler? i think i may only have enough resourses to do the 2fe then in a couple months after turbo and intercooler.
what do u think of it so far? if you could do it again would you? or would you do another swap?
ok sorry hijack over.
No, not really all that great. If you want some good sound you probably need to be releasing more than 6lbs. You could look into a BOV with and adjustable spring tension. I had a Greddy Type-S on my Miata and it sounded pretty "crisp".
Chineese knockoff external wastegate. This unit is a whole lot more consistent than the traditional internal setup.
hey akarilo, have you thought about about using SAFC for tuning? I've built several budget turbo car and this project seem like what I've done before. I would get bigger injector and use safc to get the AFR that needed. Its safer than FMU.
Forgot about this, how did the stainless weld to the mild steel exhaust?
