Can anyone tell me what this is for and weather I’m supposed to feel exhaust puffs coming out of it? (1 Viewer)
Needham ma
As the title says I’m not sure what this is but I feel exhaust coming out of it.
Wausau WI
It's a heat-driven flapper, used to drive air up against the intake when it's cold...you should have a coil spring on the other side. When it gets stuck, it causes the alu' intake to crack, so it's often removed and a blocking plate put in.
Seems like your bushings are worn if it's puffing. I pulled mine out and found some large stainless flare-head bolts that fit perfectly to block the holes, but left them intact if it ever needs to get reverted.
Can get an idea of what it looks like (factory) in this thread: 2F Intake/Exhaust/Carb vacuum issues - https://forum.ih8mud.com/threads/2f-intake-exhaust-carb-vacuum-issues.835381/
John Smith
In the garage
Maryland
Looks like a PO removed the exhaust diverter and tried to plug it with a bolt. You could pull the bolt and JB weld it in.
Needham ma
Actually I think it’s still in there I can twist it opened and closed from the other side it’s spring loaded but not attached to anything and I can hear the metal flapper opening and closing inside so I guess it just stays shut. isn’t that bad though?
I think stuck "open" where it's constantly diverting exhaust up against the intake is bad.
p.s. - It's "whether". Weather is what's coming outta my...
roadstr6
Weddington, NC
The "spring" you speak of is not just a spring. It's a bimetallic thermal coil. It reels itself in - out based on temperature changes, which in turn opens - closes the exhaust flapper inside the manifold.
