4LowandSlow
Like I said with it sitting next to the other 80 that’s getting a rebuild. LS swap it. Be Different, Be Better!
Your mom and dad don't want a LC junk yard at thier house.Like I said with it sitting next to the other 80 that’s getting a rebuild. LS swap it. Be Different, Be Better!
Yeah getting parts in Japan was a another reason why I sold my Challenger.Sorry to hear about the engine. I’d keep it original. When you get to Oki, you’d probably have a much easier time sourcing parts and not risk the Japanese bureaucracy tying you up. Or say f*** it and put an LT1 in it. Yolo
I dunno man! They both have the addiction.Your mom and dad don't want a LC junk yard at thier house.
Im too invested in the in the SC.Rebuild + Turbo. Bootleg LS swapping is for Floridians who wear cut off jorts and drive around with sideways t-case knobs.
I don't know the specifics of what that means to you, but you could sell it even used very fast for probably close to what you paid for it.Im too invested in the in the SC.
True. I was a turbo purchaser (mentioned on the first page). During the wait for the turbo, I bought the SC and sold my place in line for the turbo. Ive been in conversation with a guy thats going to re-make an intercooler for me (and maybe a few more). I like the SC and not going to back out on him when he's helping me. So ill rebuild break and rebuild again lol.I don't know the specifics of what that means to you, but you could sell it even used very fast for probably close to what you paid for it.
Lol Cute
I’ll have you know I addressed that!
View attachment 2708809View attachment 2708808
Put THAT in your pipe and smoke it
Do you already have the upgraded Whiteline rear sway bar?Since this will be a build, let me go through what I have and plans.
Engine / Trans:
PHH bypass
New oem engine isolators and transmission isolator mounts
Dizzy O-ring, and cap
Oil pump o-ring and engine crank seal
170 degree thermostat and new o-rings
New OEM spark plug wires
Supercharger
New OEM water pump
Landtank orange fan
Landtank upscale MAF in injectors
Landcruiser Phil rear heater delete hose
New heater valve
Cleaned out upper plenum and new vacuum hoses
HuddExpo EGR test sensor plug kit
Heavy duty battery wires
90 degree oil filter fitting
Armor / Exterior:
Slee short bus front Bumper
Slee rear bumper
White knuckle sliders
Warn Zeon 10S Winch
Prinsu Rack
Raptor Lined
Suspension / Axle / Wheels:
37 x 12.5 x 17 Yokohama Geolandar M/T G003
17 Method Hole wheels
Slee 4" caster correction
OME 4" heavy springs
Fox 2.0 shocks
Extended braided brake lines
Landtank 4" rear Lower Control Arms
Tetton front DC shaft
Tetton rear shaft
Nitro 5.29 gears (front and rear)
Whiteline heavy duty sway bars (front and rear)
Landcruiser Phil sway disconnect
Man a Fre rear extended drop brackets
Wits End sway bar bushing caps (front and rear)
Slee extended bump stops (front and rear)
Slee drag link and tie rod
Misc / Electrical / Interior / Lighting:
Ebay snorkle
Antenna Mounts R Us replacement stubby
ARB differential breather
Nilight 50" curved light bar
Nilight rear flood lights
Amazon Rock Lights
7pin CDL mod
Auto up window mod
Landcruiser Phil AUX fan
Landcruiser Phil shifter extension
Drawer system
Huracan Fabrication Tail gate storage
Exped MegaMat Duo 10 Sleeping pad
Dash lights replaced with LED bulbs
Wits End battery cable clamp
Wits End accessory panel unit
Solvefunction nipple guard
Scangauge II
Solvefunction Scangauge II mount
Solvefunction hood vent riser
Solvefunction cover for seatbelt mount holes
hand throttle
Delta VS ceiling storage bracket
Fresh charcoal in charcoal canister
Pending Parts and install:
New OEM wiring harness
New O2 sensors
Wits End timing chain tensioner- ratcheting, modified
Fuel Filter (again just cause)
Hood insulator
Hood rubber refresh kit
T-case rebuild
2.8 supercharger pulley
supercharger intercooler
Maybe HuddExpo GIS skid plate
Harrop Elocker (rear)
Solvefunction shakey mirror brackets
Man a Fre rear lower shock protectors
Landcruiser Phil severe duty rear sway bar links
Oil level sender
A/C compressor
Maybe depo headlights with projector and LED bulb (when I feel like wasting $800-$1000)
Yes. Well what do you mean by updated?Do you already have the upgraded Whiteline rear sway bar?
As I were. . Yes I do. Can't read at times. I have Front and rear Whiteline sway bars.Yes. Well what do you mean by updated?
I just ordered the Whiteline upgraded sway bar they other day. I need the @LandCruiserPhil heavy duty drop brackets as well. I've got to get through the engine rebuild first.As I were. . Yes I do. Can't read at times. I have Front and rear Whiteline sway bars.
We just grinded a radius in the arms to work in the meantime of running them without Phil's brackets. But the brackets are on the list.I just ordered the Whiteline upgraded sway bar they other day. I need the @LandCruiserPhil heavy duty drop brackets as well. I've got to get through the engine rebuild first.
