Build Call me Deacon Blues
Like I said with it sitting next to the other 80 that’s getting a rebuild. LS swap it. Be Different, Be Better!
Your mom and dad don't want a LC junk yard at thier house.
Sorry to hear about the engine. I’d keep it original. When you get to Oki, you’d probably have a much easier time sourcing parts and not risk the Japanese bureaucracy tying you up. Or say **** it and put an LT1 in it. Yolo
Sorry to hear about the engine. I’d keep it original. When you get to Oki, you’d probably have a much easier time sourcing parts and not risk the Japanese bureaucracy tying you up. Or say f*** it and put an LT1 in it. Yolo
Yeah getting parts in Japan was a another reason why I sold my Challenger.
Rebuild + Turbo. Bootleg LS swapping is for Floridians who wear cut off jorts and drive around with sideways t-case knobs.
Im too invested in the in the SC.
I don't know the specifics of what that means to you, but you could sell it even used very fast for probably close to what you paid for it.
True. I was a turbo purchaser (mentioned on the first page). During the wait for the turbo, I bought the SC and sold my place in line for the turbo. Ive been in conversation with a guy thats going to re-make an intercooler for me (and maybe a few more). I like the SC and not going to back out on him when he's helping me. So ill rebuild break and rebuild again lol.
so... just going to throw this out there. Don't import the 80 to Japan, and just buy one of these and make us all jealous.
Last time I was back there, they had a 70 series at a dealership near my wife's parents house. Mid next year I should be heading back there to visit. See what the market is looking like.
Since this will be a build, let me go through what I have and plans.
This will be continuously updated.
Rebuilt engine: ~175k
Knuckle rebuild: May 26, 2022
Oil change: She'll Rotella T4 SAE 15W-40 @ 184794k.
Greased driveshafts: 175639k
Tire rotation: 175639k
Engine / Trans:
PHH bypass (Mar 2022)
OEM engine and transmission mounts (2019)
Dizzy O-ring, and cap (Apr 2022)
Oil pump o-ring and engine crank seal (Feb 2022)
170 degree thermostat and new o-rings (2020)
OEM spark plug wires (Mar 2022)
Kazuma Supercharger (Spring 2021)
OEM water pump (Mar 2022)
Landtank orange fan (Spring 2022)
Landtank upscale MAF in injectors (Aug 2021)
Landcruiser Phil rear heater delete hose
OEM heater valve (March 2022)
Cleaned out upper plenum and new vacuum hoses (March 2022)
HuddExpo EGR test sensor plug kit
EGR delete (March 2022)
Heavy duty battery wires (Summer 2021)
90 degree oil filter fitting (Summer 2021)
Oil level sender (Feb 2022)
Fresh charcoal in charcoal canister (2019)
New ignition coil (Feb 2022)
LC engineering Master Rebuild Kit (Oct 2021)
ARP Head Stud Kit (Oct 2021)
Landtank's oil pump brass bushing (Oct 2021)
New OEM wiring harness (Feb 2022)
O2 sensors (Feb 2022)
A/C compressor (Feb 2022)
2.8 supercharger pulley (Mar 2022)
Supercharger intercooler (Mar 2022)
Armor / Exterior:
Slee short bus front Bumper
Slee rear bumper
White knuckle sliders
Warn Zeon 10S Winch
Prinsu Rack
Raptor Lined
Man a Fre rear lower shock protectors
Hudd Expo GIS skid plate
Suspension / Axle / Wheels:
37 x 12.5 x 17 Yokohama Geolandar M/T G003
17 Method Hole wheels
Slee 4" caster correction
OME 4" heavy springs
Fox 2.0 shocks
Extended braided brake lines
Landtank 4" rear Lower Control Arms
Tetton front DC shaft
Tetton rear shaft
Landtank rear DC driveshaft
Delta VS panhard bracket
Nitro 5.29 gears
Whiteline heavy duty sway bars (front and rear)
Landcruiser Phil sway disconnect
Man a Fre rear extended drop brackets
Wits' End sway bar bushing caps (front and rear)
Slee extended bump stops (front and rear)
Slee drag link and tie rod
Dobinsons adjustable rear upper control arms
Whiteline front adjustable panhard bar
Harrop E- Lockers front and rear
RCV Cromolley front axle.
Landcruiser Phil severe duty rear sway bar links.
Misc / Electrical / Interior / Lighting:
Ebay snorkel
Antenna Mounts R Us replacement stubby
ARB differential breather
Nilight 50" curved light bar
Nilight rear flood lights
7pin CDL mod
Auto up window mod
Landcruiser Phil AUX fan
Landcruiser Phil shifter extension
Landcruiser Phil batter tie down
Jim's Machinework battery terminal plate
Homemade drawer system
Huracan Fabrication Tail gate storage
Exped MegaMat Duo 10 Sleeping pad
Dash lights replaced with LED bulbs
Wits' End battery cable clamp
Wits' End accessory panel unit
Solvefunction nipple guard
Scangauge II
Solvefunction Scangauge II mount
Solvefunction hood vent riser
Solvefunction cover for seatbelt mount holes
hand throttle
Delta VS ceiling storage bracket
Hood insulator
Hood rubber refresh kit
Loncky leather steering wheel
Red hazard button
Rosen Aircraft Sun Visors
Depo headlights with projector and LED bulb (Bi-LED: Moimoto M LED Stage III; High Beam: Profile Headlights)
OEM Hood Rod kit
AEM EGT gauge.
AEM Air/Fuel Ratio gauge.
AEM Boost gauge.
Wits' End Useless Ashtray Switchplate
Factor 55 Ultrahook
Rear double cup holder
Glove box grab bar.
Wits End' Useless Cubby Insert - base
Wit's End fire extinguisher mount
Pending Parts and install:
Wits End timing chain tensioner- ratcheting, modified (part is on back order)
T-case rebuild (awaiting install)
Solvefunction shakey mirror brackets (awaiting install)
Dobinsons adjustable rear panhard bar
Fender signal markers (awaiting install)
Kut Snake fender flares (awaiting install)
Wits' End Piece Pipe (awaiting install)
I’ll have you know I addressed that!
Put THAT in your pipe and smoke it:grinpimp:
Engine / Trans:
PHH bypass
New oem engine isolators and transmission isolator mounts
New OEM spark plug wires
Supercharger
New OEM water pump
Landtank orange fan
New heater valve
Armor / Exterior:
Slee rear bumper
Warn Zeon 10S Winch
Prinsu Rack
Raptor Lined
Fox 2.0 shocks
Tetton rear shaft
Nitro 5.29 gears (front and rear)
Wits End sway bar bushing caps (front and rear)
Ebay snorkle
Amazon Rock Lights
7pin CDL mod
Auto up window mod
Drawer system
Wits End battery cable clamp
Wits End accessory panel unit
Scangauge II
hand throttle
New O2 sensors
Fuel Filter (again just cause)
Hood insulator
T-case rebuild
supercharger intercooler
Maybe HuddExpo GIS skid plate
Harrop Elocker (rear)
Oil level sender
A/C compressor
Maybe depo headlights with projector and LED bulb (when I feel like wasting $800-$1000)
Do you already have the upgraded Whiteline rear sway bar?
As I were. . Yes I do. Can't read at times. I have Front and rear Whiteline sway bars.
I just ordered the Whiteline upgraded sway bar they other day. I need the @LandCruiserPhil heavy duty drop brackets as well. I've got to get through the engine rebuild first.
We just grinded a radius in the arms to work in the meantime of running them without Phil's brackets. But the brackets are on the list.
