Is your pinion nut loose? It may cause that.
Yes, thanks for making sure I clarify. I'm assuming it's much more backlash than there should be.As in the backlash?
Couple of questions here to get better understanding:I'd check the pinion nut to see if it backed off. Changing that bearing preload can do that. Don't overtighten the crush sleeve, though.
- if a nut backed off, would that changer the backlash? I believe that would move the pinion gear closer to the ring gear hence reducing the backlash.
- I can't find a crush sleeve in this differential. I thought maybe that it was left off but I can't find it in the parts catalog for the '73 F40.
- when i removed the nut and opened things up, the outer bearing came right off. is it supposed to be lose or pressed on?
Wow, great post. Unfortunately I don't have a back panel on the front diff that i can remove like on the rear diff so I would have to take it out. I don't remember any side to side nor in/out movement so perhaps I'll try to torque the pin for now. If it doesn't fix things then i'll take the 3rd member off to inspect spider gears.In post #86 with the 2 videos showing how much the pinion flange rotates. The rotation is not all backlash between the ring and pinion. Most of the rotational slop is from the spider gears coming in contact with either the carrier or the side gears. Only a very small amount of rotation is from the backlash setting between the ring and pinion, unless all the bearings are shot. The carrier is the part the ring gear bolts to. If you want to see this you can remove the rear cover and watch what happens when you turn the pinion flange and look at the spiders. Backlash is measured between the ring and the pinion, and the 3rd member has to be removed from the housing to adjust it. If all the bearings are good the Backlash settings are usually less than .020" Preload refers to rotational resistance between the pinion bearings and races, and has nothing to do with the actual ring and pinion setup. Its a measure of resistance to insure the bearing are seated correctly. You'll find the preload spec on new bearings to be higher than on old bearings. After driving it for a while, the preload will slightly go away as the bearings and races seat.
B4 you removed the pinion nut and yoke/flange, did the flange have any movement in and out or side to side(wobble)? If not then I'd bolt it all back together. And torque the pinion nut to spec. In your last video you can see the shims and pinion spacer 1 sec in. close up. There's a very slight shoulder just below them. The ring and pinion are helical gears and they don't mesh like straight cut gears. When you tighten the pinion it is supposed to move away from the pinion. The gears mesh at a sweet spot and create a contact pattern. If you look in your manual on diff setup you will find a page with pics of contact patterns and adjustments to get the correct contact pattern.
Strange, but my 82 has a hole just like that.Yours will help me understand what mine was supposed to look like.![]()
Was there any options that that could have bolted on the front in this hole? PO filled a lot of holes in the body (emblem holes, rubber windshield pads, etc.) but not this one.
