Unlike the four speed, the three speed needle bearings are all like free-range chickens: no cages!I'd say all new bearings. If the needle or roller bearings fell out the races that held them in are shot.
Ya, I think that they just fell out when I was taking the counter gears out. stillt trying to figure out where the larger rollers go, looks like around the 2nd gear. it's a puzzle, I like puzzles.Unlike the four speed, the three speed needle bearings are all like free-range chickens: no cages!![]()
Good point. I'll clean and see what needs to be replaced and place an ad.There are enough people abandoning three speeds that if you’re dead set on having the experience of rebuilding one without buying anything from a vendor, I’d still recommend posting a want ad for a different core. Pitted gears will chew themselves up quickly.
I just got FAQ'dPlenty of information on that in the FAQ section.![]()
But, you got FAQ'd by Mark A. So you got that.I just got FAQ'd![]()
Dang, I wasn't ready for that can of worms in the FAQ on the J30 to 4-speed conversion. Lots of opinions flying around o what exactly it takes... I'll skip that thought for now until I figure out how solid the rebuild will be.Plenty of information on that in the FAQ section.![]()
There are 2 wires going to the fuel gauge; it is my understanding that one of which is 12v and the other is a ground. Do you know which one is which? It appears that the hot would be the yellow with green (closest to the ampmeter). I will be installing a new Dakota Digital instrument cluster this weekend and need to figure out the fuel gauge wiring. Thanks.Debugging Fuel gauge caused me to clean things up. fingers crossed on getting it back together, those gauge wires are super fine and delicate. Took out one of the glass panels but stopped there as the rubber piece just was crumbling. I'm guessing these aren't available.
View attachment 2817080View attachment 2817085View attachment 2817082
There's more variance in this wiring then I thought. All depends upon year of your FJ40. But yes, the red on yellow wire (C on the diagram) goes to the sender gauge on the fuel tank. the other terminal at the sender on the fuel tank is just grounded.There are 2 wires going to the fuel gauge; it is my understanding that one of which is 12v and the other is a ground. Do you know which one is which? It appears that the hot would be the yellow with green (closest to the ampmeter). I will be installing a new Dakota Digital instrument cluster this weekend and need to figure out the fuel gauge wiring. Thanks.
Very helpful. Good luck on your build which I'm following. Thank you.There's more variance in this wiring then I thought. All depends upon year of your FJ40. But yes, the red on yellow wire (C on the diagram) goes to the sender gauge on the fuel tank. the other terminal at the sender on the fuel tank is just grounded.
The Fuel gauge is also powering the water temp gauge.
Debugging is a pain since the voltages are all over the place with the coils. I should get an oscilloscope.
View attachment 2817847View attachment 2817848
