Your truck looks great. Where did you get the wraps?Thank you!
I actually have a wrap over the tail lights. I wish I had the sport tails but decided against paying the premium
I’m not sure about the harness but I don’t think they changed in 2021.
Thanks! I got it from Login • Instagram - https://www.instagram.com/bluebatoverlays/Your truck looks great. Where did you get the wraps?
Thanks! Looks like a pain either way! ha. I'm terrible with that kind of stuff.Thanks! I got it from Login • Instagram - https://www.instagram.com/bluebatoverlays/
Shoot him a DM and tell him @18gx460 sent you.
If I were to do it again, I would buy the vinyl without the amber cut out, apply it then make the cut out myself once it dries. Applying the tiny strip of vinyl that results from the cutout is a pain.
Maybe reach out to a local shop for a quote. I have some experience doing it and mine didn't turn out all that great around the edges. Specially because there isn't a lot of spare material to stretch out.Thanks! Looks like a pain either way! ha. I'm terrible with that kind of stuff.
Here’s a couple more pictures, I was bored
Carmarka. But they are secuencial turn signals.Are those the Chi-Com sequential tail lights?
So clean. Love it. How do you like the tail lights? I'd love to replace my "altezza" tail lights.
Got this one. Working well so far.Which dash cams did you add?
"one try, huh?" haha
One thing I don't quite understand about dash cams is how long do they run before they write over themselves.Got this one. Working well so far.
REDTIGER Dashcams Front Rear Dash Camera 4K/2.5K Full HD Car Dashboard Recorder with 3.16” IPS Screen, Wi-Fi GPS Night Vision Loop Recording 170° Wide Angle WDR, Free 32GB Card https://a.co/d/0c2LSB9
Also, running power from the rear view mirror using this:
Dash Cam Install Easy as 1..2..3..
Convert your mirror into a power source for your dash cam!dongar.tech
Easy install and less wires.
Lol she knows it was!
All depends on the size of the memory (eg SD card) and quality of video you choose. My cam captures up to about 2hrs of vid before writing over IIRC. It also has a built in feature to auto save footage from write over following an impact. Some cams also sync with your phone so saving to the cloud is also an option.One thing I don't quite understand about dash cams is how long do they run before they write over themselves.
I assume the camera will record to an SD card or something and after so much time, will record over itself unless you remove the memory for an accident, or whatever reason you need to review the recording.
Is that correct?
If so, how long do they record for?
Can you trace the existing faring over a piece of plexiglass (Acrylic) and have your light bar behind it? I did that with mine and it helps keep the wind noise down.Anyone ever cut their Prinsu or other roof rack wind deflector?
Been thinking about it to make the notch to fit a light bar.
Was thinking it’s doable with an angle grinder but making it perfectly straight might get tricky.
Want to avoid paying for a new one![]()
