I have been on the fence about going to military surplus wheels and tires. Looking forward to your testing.
I need to stop looking at this thread. Those wheels are a big pile of sex. Want.
Yea fxxx that.
I run the trail worthy fab wheels with a pressed center. They are straight and true, the weld in centers are for Offroad use only. The press fit centers will sit the tire flush to the flair if you still have flairs.
The dual beadloc is the way to go for sure, heavy tho. Why did you opt for the million bolt wheel? Curious, the 8 bolts are more then enough given our 80's weight.
Ammo
Pressed centers are stronger. The "pressed" refers to them being stamped steel, giving it more structural rigidity. They are still welded in, but only can be had in 3.5" backspacing or less. They tend to run more true.
The "welded" centers are cut out of steel plate, so they are flat. This allows more than 3.5" of backspacing but they can bend easier because they are flat and are **** near impossible to make run true.
The dual beadloc is the way to go for sure, heavy tho. Why did you opt for the 24 bolt wheel? Curious, the 8 bolts are more then enough given our 80's weight.
Why not go with the 24 bolt wheel? The 24 bolt wheel is more robust and most of them are in better shape than the old school 8/12 bolt wheels. Why not go with a better wheel when it's available for only a few dollars more? Some people say because it's a hassle to tighten 24 bolts on each wheel. That is just silly, you're not pulling the wheel apart once a week. It's something you do once in a blue moon or when you're replacing tires. So the answer, because it's a better wheel and the price/weight are nearly the same.This is the 80 section if some is good more is always better!!I am not sure the 8 bolt wheels are a good example there have been a lot of problems with 8 bolt wheels not sealing. Not to mention it is stamped right on the 8 bolt wheel that it is only rated to 30psi, most D or E rated tires are rated to 65psi. So at the minimum I would go 12 bolt if you are doing HMMWV wheels.
I didn't get a chance to take pics of the CNC machined adapters before we put them on the truck. Once we pull them off for the preliminary inspections I'll snap a few photos for you guys.So let's see the adapter?
You aren't the only one I have checked this 5 times in the last hour.
Sent from my iPhone using magic
They do look nice dont they? I've been getting rubberneck looks and people hanging out of their windows camera in hand in parking lots. To be honest it was more of a functional thing for us, I didn't think it would get so many looks.I need to stop looking at this thread. Those wheels are a big pile of sex. Want.
I ruptured a disc just looking at those.
How much do they weigh?
They're not a light weight racing wheel/tire setup by any means. But as scottryana mentioned, they're not much heavier than a single beadlock wheel. If you're going to go with beadlocks they're a great choice IMO.Well to compare apples to apples a 37" Goodyear MTR with a Walker Evans Aluminum single beadlock is a 73lb tire and a 43lb rim so 116lbs combo. For 14 more pounds you get a steel double beadlock. For some applications it works well, for others total overkill.
Soon.Hurry up with that testing already I "need" those
